Lower boost, what could it be?
Old Apr 28, 2017, 07:19 AM
LSs1Power's Avatar
My lower map tune usually see 25-26psi and drops to 18psi by 8k RPM. My higher boost map usually see 29-30psi and drop to 18psi by 8k RPM.
For some reason now, my low map doesnt pass 20psi while my hi map peg at 25psi. They will both come down to 18psi by redline.
I checked for leaks and didnt find anything. Is the stock Turbo done? What could it be?
Old Apr 28, 2017, 07:41 AM
static_set's Avatar
might be having a wastegate mechanical issue?
-asher
Old Apr 28, 2017, 11:11 AM
LetsGetThisDone's Avatar
Received 1,548 Likes on 1,327 Posts
What did you do to "check for leaks"? The only way to properly do this is to do a boost leak test by pressurizing the system.
Old Apr 28, 2017, 12:11 PM
LSs1Power's Avatar
-asher
It could be, its a crushed wastegate but never had an issue with it before.
I was trying to do a baseline pull before changing the turbo to 18k. If its the wastegate i wont try to fix it as the new turbo comes with its wastegate.
Old Apr 28, 2017, 12:14 PM
LSs1Power's Avatar
I checked all the clamps and hoses and everything is tight. Im planning to pressurize the system tomorrow to double check.
I dont want to put a turbo on until i know the issue first. Otherwise i will have many variables to check later and it becomes harder to diagnose.
Old Apr 28, 2017, 12:20 PM
Yeah, a visual check is only going to catch something super obvious like a torn coupler or super loose clamp, which the car wouldn't even make the boost it's making now. Gotta do a pressure check.
Old Apr 29, 2017, 01:08 AM
LSs1Power's Avatar
Just completed the pressure test, no leaks.
I think the stock Turbo is shot. Anyways its a good thing i had the 18k Turbo in the back seat. We started the swap now.
jameswwt
18
Dec 2, 2012 11:49 PM
EVOEvolved
Nov 20, 2012 05:55 AM
otbEVO
Sep 9, 2006 11:15 PM
faiwu
Apr 17, 2003 09:44 PM
Quick Reply: Lower boost, what could it be?
