Sponsored by:
Sponsored by: CARiD
EVO X - Gas Mileage?
Old Aug 16, 2016 | 10:05 AM
  #136
Noize's Avatar
EvoM Administrator
17mpg average on E40.
Old Aug 16, 2016 | 12:32 PM
  #137
RazorLab's Avatar
Originally Posted by moparfan
Can e85 bros let us know what kind of gas mileage they get? (e85 mpg and average miles per tank)
14.56 MPG average over 18,515 miles and 1,240 gallons. Average of E78.
Old Aug 20, 2016 | 09:46 AM
  #138
travbabble's Avatar
23 on the highway, 17 combined. Bone stock.
Old Oct 5, 2016 | 04:17 PM
  #139
Olegator's Avatar
averaging about 18mpgs
Old Oct 6, 2016 | 07:35 AM
  #140
kyoo's Avatar
Originally Posted by KRome
You'd be surprised how much of a difference 500RPM drop will make. I know it's a poor comparison but, the 5th gear in my civic was very short with a 4.7 final drive and when I added a 6th gear from a TSX and used the 4.3 final drive ring from a base RSX, I dropped 1500 RPM at cruising speed and was able to achieve 35+mpg with over 400WHP on tap.
Keep in mind, yes my civic weighs under 2800lbs with me in it and it is front wheel drive, but I have faith that with the offerings Sheptrans has, I can change my 21-22 & 24-26 to in the ballpark of 24-26 and 27-29mpg with the Evo.
I also plan on getting some 17" wheels that will clear the calipers, I tried to test fit my 17" RPF1's but the offset (+45) was too high and the inner wheel wouldn't clear. I believe a lower offset 17" wheel is possible to further help economy and keep the quick acceleration of the car.
Maybe with a tune I might just be able to break 30mpg, we'll see. I know this is a rally car for the road but you CAN have power and economy, you just have to figure out what works.
I totally agree with the sentiment, but these cars are just not very efficient. You won't pick up anything with a tune FYI, tune really only touches the WOT and upper RPMs. I think to get in the upper 20s region, you'll want to be 2500-3000rpms, with narrower tires than 245s (I run 225s for my daily tires). on my 9 with 6 speed, I haven't broken 30mpg. if I were totally on local highways going 50mph, I'm sure I could, but not on normal interstates.
that said, looking forward to seeing your progress on the build!
Old Oct 7, 2016 | 06:51 AM
  #141
BluEvo210's Avatar
Originally Posted by kyoo
I totally agree with the sentiment, but these cars are just not very efficient. You won't pick up anything with a tune, FYI, tune really only touches the WOT and upper RPMs.
It depends on the tuner. When Chris Carbee tuned my car, he made a huge improvement in part-throttle driveability.
The tuner before him apparently only changed the WOT parts of the maps, and didn't lean out the mixture at all, so that fool actually cost me 1mpg.
Old Oct 7, 2016 | 07:17 AM
  #142
kyoo's Avatar
I'm confused - as far as cruising, shouldn't it target stoich? I see partial throttle part boost to run a little leaner than it should, but you won't really be picking up any significant mpg from that. or did he tune leaner than stoich for cruising?
Old Oct 9, 2016 | 11:32 AM
  #143
BluEvo210's Avatar
Yes, and I don't think Mitsubishi did that.
I think Mitsubishi prioritized the safety of the engine, and made the Evo X run rich at nearly all parts of the fuel map. I bet you don't even have to lean it all the way to stoichiometric to see an improvement in throttle response and gas mileage.
I remember when I had my car for a couple of months, and gas prices climbed over $4.00/gal, Works started offering their "Brain Flash Eco" to save Evo owners some gas.
http://store.worksmotorsports.com/WO..._p/107.102.htm
I thought it was evidence that Mitsubishi half-assed the factory software. They probably figured "Everyone is going to hack it, anyway. How much effort should we really put into it?"
I think their marketing targeted drivers who would be trading in gutless small-bore cars with weak throttle response, and a lot of Evo owners would be telling each other "You don't buy these cars for gas mileage." So they tuned it well enough to impress the target demographic on the test drive, and made sure it would never, ever run lean on stock software.
Old Oct 9, 2016 | 11:56 AM
  #144
RazorLab's Avatar
All of this is absolutely incorrect and not fact based.
The car runs stoich at cruise from the factory, it always aims for stoich cruise. That is 100% fact and is programmed that way. I can show you proof in the tables and logs.
There are other ways to create better mileage at cruise than just fueling. Mivec, timing, open loop / closed loop stategies, etc.
You would be surprised what even just careful tuning of the mivec tables does for cruising mileage.
I also challenge that unless you are running the car in a 100% controlled environment, a 1mpg difference before/after should be considered within the line of data error and should be discarded.
Old Oct 9, 2016 | 04:19 PM
  #145
Ducky077's Avatar
2014 18k miles on the car and getting about 22-23mpg, all stock exept catback.
Old Oct 10, 2016 | 04:09 PM
  #146
kevinlambchops's Avatar
I average 15mpg, calculated it myself. Total gallons/miles driven. FBO E85
Old Jun 11, 2017 | 04:47 PM
  #147
EVOXFINEST's Avatar
This has to be higher than 25mpg ? Bone stock '15FE .
Average speed is 60 mph on highway.
Old Jun 13, 2017 | 07:50 AM
  #148
cloom2000's Avatar
ohh wow, when i fill up tank in my evo i got range 200 miles
Old Jun 13, 2017 | 10:41 PM
  #149
moparfan's Avatar
I get about 21-22 mpg in mixed city/hwy driving (50%/50%). Most of the time I'm driving pretty sedately.
Old Jun 14, 2017 | 10:04 AM
  #150
booloop's Avatar
I'm getting anywhere from 14-19 on my daily drives. Bone stock '15 with 3500 miles on 91 octane. I don't drive like a madman but I certainly have fun with the car.
