EVO X - Gas Mileage?
How about some real measurements and not picking numbers out of the arsh?
Fill the tank up.
Reset ur A trip meter.
Drive till your next fill up.
Take the amount of gallon put into the car.
Divide that with the mileage that is showing on trip A meter.
That should give you real world MPG.
I currently have a Fit and getting around 33-35 MPG.
I do 60% highway.
Back when I had the Evo8 same driving style I got 16-18 MPG.
Rarely driven hard.
I'm curious to know how the car estimates MPG then the real world MPG.
Fill the tank up.
I do 60% highway.
Rarely driven hard.
OK, here's the deal. I am still not factory reflashed. The above mpg was with mixed driving, breaking in the engine hard at times.
Now, most recently, on a fresh tank of gas and an oil change to Mobil 1 10-30, I went on a 160 mile freeway trip (constant 75 mph), and about 30 miles of city driving. My fuel guage was completely empty before I even hit 200 miles!!!!
I dont understand how everyone is getting this bad of milage. Are you guys in like constant boost? I mean it is a 4 cylinder...shouldnt it be getting insane milage????
My 03 cobra averages just a hair under 20MPG. And gets 24 on the highway. I would think mine would be WAY behind you guys. hmmm anyone have any input as to why this is? Driver related or just the nature of the beast?
I don't understand why people are so baffled by the gas mileage. A better way to think about it than in liters or in cylinders is to think of it in terms of power. There is a direct correlation between power and gas mileage, and its not a positive one.
The short 5th gear does not help matters either.
If you look at an 08 Corvette that makes 436hp, they can still get very good highway mileage, I have read of 26-28 mpg, but this is due to the very low .50 6th gear OD. They just let the engine tick over at low rpm's to get it, but the engine does not mind it just churns over and pulls it.
Thread back from the dead. I'm getting 240 miles to the tank, MAX with an FP Red, 1000cc injectors, 11.2:1 AFR, beating on the car here and there.
That sound about right to whoever is modded?
- Louis
- Louis
