Sponsored by:
Sponsored by: CARiD
Understanding ASC: What it does and reported problems & codes (thread merge)
Old Nov 13, 2008 | 08:46 AM
  #136
Teh Rob's Avatar
Originally Posted by TTP Engineering
If you were a betting man, you would have lost because the ones not receiving the light only use TARMAC mode.
Read one post above me.
Old Nov 13, 2008 | 08:48 AM
  #137
TTP Engineering's Avatar
I don't think you understood.
Out of the ones that do not get the light at all, those users have only used TARMAC mode.
Old Nov 13, 2008 | 09:08 AM
  #138
Teh Rob's Avatar
So some of those who haven't gotten an ASC light are using Tarmac mode. I get that. But there are people who have gotten the light in Tarmac mode as well and stated that they switched to Snow mode and it didn't come on as much.
Old Nov 13, 2008 | 09:14 AM
  #139
junction's Avatar
Originally Posted by Chris@AMS
None of my customers have had any ASC light issues, from any part of the world. The JDM ECU's are all good too. I have flashed some cars over 50 times (due to changing modifications and testing) and have yet to have a problem when using ECUTeK.
My car was tuned at AMS in August and haven't had any issues whatsoever.
Old Nov 13, 2008 | 09:36 AM
  #140
JWA's Avatar
JWA
Congrat's on the awards, and thanks for the update on how you're monitoring the issue to get to the bottom of it. Coming from a software background, I know how fun the debugging process can be. Good luck with it, and I'll be watching to see how things go.
Old Nov 13, 2008 | 10:31 AM
  #141
Chriso3030's Avatar
I was one of the first customers to recieve the z-chip and in fact was the first one to comment about the ASC light coming on. Unfortunalty I put mods on the car first so I was never able to tell what caused what first. I recently had my buschur catback removed and went back to stock, and wouldn't you know it, my ASC light has yet to return. Now buschur and AWD motorsports(the company that removed the exhaust) say they have never heard of any issues with the light coming on from the exhaust at all, But i'm sure there are people reading these threads that know that the ASC light has come on from bolt-on mods alone (i've read people's post's about it) so surely there are some ecutek ASC light issues. Are people that die-hard about there reflash that they don't want to admit one ASC light problem? or do they not want to contribute it to their reflash? Anyways, My ASC light problem is gone(so far).
Old Nov 13, 2008 | 10:37 AM
  #142
Wow! Straight and to the point Chris.
Old Nov 13, 2008 | 10:39 AM
  #143
Expect RobiSpec to share a much needed explanation of the SAWC system as well as his input on what most likely causes these ASC lights to come on.
Old Nov 13, 2008 | 12:03 PM
  #144
AWD Motorsports's Avatar
Fortunately Chris, We have not had ASC Light issues.. AL @ Dynoflash was here yesterday and tuned 2 Evo X's which both made 345-350whp and neither experience the issue.. We have in car video of hard cornering in the MR and WOT and no lights.. I am sure it will get worked out but stating that Flash guys are getting the light but not speaking of it is a TOTALLY FALSE statement.. Why would flash customers deal with the issue after paying 750.00 for flash..
Old Nov 13, 2008 | 12:24 PM
  #145
JDMEvo9RS's Avatar
It was amazing to read about your results on the zchip without the catback Chris. Putting down +72whp on the zchip in your stock car on AWDMotorsport's own dyno says something about the pnp product. The fact that your car does not have the ASC light after you removed your catback is very interesting info that points to either high torque to the rear wheels vibrations from the exhaust..
I have read that the SAWC module actually APPLIES BRAKES to the rear wheels when too much torque is going to them. I found that very interesting and may be the cause of the light.
Old Nov 13, 2008 | 12:30 PM
  #146
lallen3's Avatar
I'd have to agree with this. If I paid that much for a tune, I'd be concerned/upset if it were causing a warning to go off.
I have removed my MBC & Intake just to see what happened, and the ASC lamp still comes on, so I know for a fact there is something relating to the Zchip causing it.. I'm not saying the Zchip itself is the cause (electrically speaking), but perhaps the resultant power gain. It's just odd that cars tuned "harder" than mine aren't getting the lamp, but mine is. I boost at 24psi, spiking at up to 26 at times, and have the Cobb tuning intake. No other mods at all. We need someone to post the DTC set by the ASC module. (This century would be helpful! )
  #147
Again whats ODD is that Both cars here yesterday that were Ecutek flashed had Buschur Catbacks on them and made 100whp Approx and no lights..
Old Nov 13, 2008 | 12:33 PM
  #148
lallen3's Avatar
The Don't confuse the ASC/ABS module with the S-AWC control unit. They are separate. Also, when the system is fully disabled (3 sec push), the brakes cannot be applied to any wheel for stability purposes, only normal & ABS braking.
Old Nov 13, 2008 | 12:38 PM
  #149
EVIL_EVO_VIII's Avatar
I had a 9x whp and 9x wtq gain and have NEVER had a ASC light come on under any conditions with the zchip. I have cornered the car hard, done wot pulls from every gear to about 130mph and NOTHING!
My car is bone stock for the exception of the zchip and a Forge UNOS mbc
Old Nov 13, 2008 | 04:52 PM
  #150
Papi4baby's Avatar
Dyno please. Or link where the results are showned for your car, thank you. Were you a plug and play customer or a custom tune zchip customer?
