Sponsored by:
Sponsored by: CARiD
Understanding ASC: What it does and reported problems & codes (thread merge)
Old Jan 22, 2009 | 09:52 AM
  #331
Rguy's Avatar
Did this have anything to do with removing your steering wheel?
Old Jan 22, 2009 | 09:54 AM
  #332
wild01ride's Avatar
Originally Posted by rogue
Looks like the issues is a Steering Angle Sensor. They tried to recalibrate it but the sensor was still out of the required range. Looks like Saturday before I get my car back.
Hmm - clockspring...
Did you happen to pull the steering wheel to do the S-AWC switch relocation or for any other reason?
Other than that, probably just a defective part.
It's best that it crapped out completely and will be replaced, because if it was intermittent, it would screw with your S-AWC since it's an incredibly important part of the system (specifically the ACD and AYC).
At least you're getting it fixed sooner than later.
  #333
rogue's Avatar
I was thinking that at first, but I never rotated the wheel, or moved it from its standard position. Just off and back on.
Old Jan 22, 2009 | 10:02 AM
  #334
rogue's Avatar
Yea, the S-AWC switch relocation was done.
They say it is not broken, they just can't get it to calibrate properly. Weird. Oh well. At least it is not something really major.
Old Feb 15, 2009 | 06:52 PM
  #335
MR Dan's Avatar
Another ASC light issue
Today the ASC OFF light was flickering on and off and now its completely on and wont shut off. I even disconnected the battery but no luck. Common problem I guess?
Car: 08 GSR
Miles: 2200
Mods: Intake only!
Had dealer #2 factory reflash
Old Feb 15, 2009 | 08:50 PM
  #336
EndlessRed's Avatar
wow only 2200 miles...slap your stock intake back on if you have it, and visit the dealer.
Old Feb 15, 2009 | 09:01 PM
  #337
tomatoEVO's Avatar
same way it happened to me. i got it like 4 months ago, still haven't serviced it. probably going this friday.
Old Feb 16, 2009 | 12:05 AM
  #338
evo_turbo's Avatar
shld find ur dealer abt it.
Old Feb 16, 2009 | 07:29 AM
  #339
stokEd's Avatar
Car: 08 GSR
Miles: 2200
Mods: Intake only!
Is this the first time this has happened? You could try hooking up an OBD II scanner and see if there are any DTC's that need to be cleared (but if there are DTC's you don't want to clear them before going to the dealer.) And can you tell that the ASC is actually off?
Old Feb 16, 2009 | 08:16 AM
  #340
MR Dan's Avatar
^^ Yes the ASC is completely off since the S-AWC motion screen (Which moves when you turn hard corners) is turned off also.
Old Feb 16, 2009 | 08:21 PM
  #341
MR Dan's Avatar
UPDATE:
Visited the dealer, they scanned the S-AWC computer and it was getting the steering position sensor error. The service manager placed a order for a new steering position sensor (retails: $200ish). One of the service techs re-calibrated the current sensor and the codes were erased . I will post for any updates.
Old Feb 16, 2009 | 09:15 PM
  #342
tomatoEVO's Avatar
UPDATE:
That's what I was told when I visited the dealer too. What is it with this car? Faulty pumps, sensors, etc.
Old Feb 16, 2009 | 09:42 PM
  #343
MR Dan's Avatar
^^One of the techs told me to cut down on the U-turns
Old Feb 17, 2009 | 07:06 AM
  #344
tomatoEVO's Avatar
LOL, right. last time i went, they told me it was probably because i ran a curb, i'm like c'mon you kiddin?
Old Apr 6, 2009 | 10:19 AM
  #345
FushunEvo's Avatar
asc service required?
i just installed the greddy comp ti-c and everytime i really step on it the asc light comes on. I think it comes on like right after 4 k when the car really starts to pull. Is this a bad thing cause i don't feel any difference with the light coming on.
