Sponsored by:
Sponsored by: CARiD
Recurring P1235 code...
Old Oct 14, 2009 | 03:24 AM
  #46
gunzo's Avatar
Originally Posted by Webman
Again, the first two times I had this problem, it wasn't cold. the very first time I had the issue, I wasn't even in this state. It doesn't have any correlation to temperature. However, every time I have had the problem, it's been wet out.
Also, how exactly does a downpipe, and nothing else, increase the breathing? Remember, stock manifold, stock cat-back, aftermarket downpipe. When you have the bottleneck of the stock cat-back system, how does that improve breathability aside from the extra volume in the pipe itself?
Look .. think of the engine as YOU ..
ask yourself this question .. you breathing out thru a straw is easier or you breathing out thru a 0.5" pipe ?
Now using this same pipe, you use the straw as the exit point .. don't you thnk its easier INITIALLY to breathe out but then you hit he bottleneck of the straw later ?
YOU are having problems because BEFORE you even hit the bottle neck . you've already changed the flow characteristics of how the engine behave ..
All these are possibilities .. once the car is no longer 'stock' .. you're fair game to how the ecu think what is stock ..
There is no mystery to this ..
If you're really free .. go flip over the BOV .. I'll guarantee you'll trigger 3 codes .. P1235 P1238 and P1241 .. but have you changed the flow in anyway ?? or changed the way the engine breathes ?? .. answer is no
Trust me .. with the X .. just get it tuned .. the mitsubishi techs will NOT EVEN know its been changed .. they can only read the serial number of your ECU rom.. but not the contents ..
Old Oct 14, 2009 | 08:01 AM
  #47
Webman's Avatar
Interesting. Well, one of the things I DO want to do is go and get the Cobb AP. So maybe that's the route to go, rather than getting a custom tune that I can't change. Plus, my understanding is that a tune alone from the guy here (Tobz) is more than half the price of the Cobb AP.
Well, should have the car back today, so we'll see how far I can make it before it triggers the code.
And yeah, I Agree. If this problem comes up again, I may start pushing them to put the stock downpipe back on.
Old Oct 14, 2009 | 08:05 AM
  #48
goofygrin's Avatar
The accessport might not be the best solution for you with it's off the shelf maps.
Get an ECUFlash map from a local guy that can support you and you'll be happier IMO. I had an accessport and switched over to ECUFlash.
The support of gunzo, tephra and the others on the forums is invaluable.
Old Oct 14, 2009 | 08:24 AM
  #49
Webman's Avatar
It's easier to breathe through the bigger pipe, of course.
But breathing would not initially be easier with the straw, because when I push air into the larger part of the pipe, it still must displace the air that is in the large part of the pipe, through the straw. And without compressing the air inside the larger part of the pipe (which COULD be happening in that larger downpipe), it doesn't make it easier to breathe. The displacement must still happen via the straw. That's my thinking behind it. So, I guess there's a tad more air that can be placed in part of the system, but the overall capability of air flow through the exhaust is still the same, only that one part of the entire exhaust system has slightly more volume for air in there. Either way, the rest of the system is still a bottleneck, which makes the speed at which it an breathe, the same, but gives it slightly more air capacity.
I like these problems that make our brains work, lol.
Old Oct 14, 2009 | 08:25 AM
  #50
Mendo's Avatar
ECUflash is good. But don't forget that the Cobb AP allows to change to different maps very easily. For me, switch between maps ez is the best feature.
Old Oct 14, 2009 | 08:27 AM
  #51
Webman's Avatar
I agree with that, but it also gives me the ability to get it custom tuned...
What made you unhappy with the AP that made you switch?
Old Oct 14, 2009 | 01:48 PM
  #52
kijima's Avatar
This is true.
Old Oct 14, 2009 | 01:50 PM
  #53
migs647's Avatar
I know this has been brought up before but never received an answer. Is there any proof they can read a flash count? I've heard from some pretty reliable sources their isn't any proof. Can anyone confirm this?
Old Oct 14, 2009 | 03:04 PM
  #54
Webman's Avatar
Yeah, I thought they could see the number of times it had been flashed, and if so, they could tell how many times it should have been flashed based on previous work...
But hey, if they can't tell the Cobb AP has ever been on there, how would they be able to tell if any other flash had ever been on there?
Old Oct 14, 2009 | 03:06 PM
  #55
migs647's Avatar
Exactly. The AP is great and all, but it isn't as powerful and accurate as a custom flash. In the end, I didn't feel it was worth the $700, especially when I can get a Dyno Tune ECU Flash for $350.
Old Oct 14, 2009 | 09:12 PM
  #56
slo4g63's Avatar
Damn Ricky, sorry to hear about the bad luck. Hope it all works out for you....
Old Oct 15, 2009 | 11:26 AM
  #57
philamthebest's Avatar
how much was the MAF Sensor?
Old Oct 15, 2009 | 11:43 AM
  #58
madfast's Avatar
bump for an answer. gunzo? kijima? anyone a mitsu tech here?
Old Oct 15, 2009 | 01:43 PM
  #59
kijima's Avatar
Yes, you can dependant on the tool you are using.
You have to be more specific in your question. If you were to ask if your dealers MUT III could see a count, then the answer would be no.
Old Oct 15, 2009 | 02:12 PM
  #60
goofygrin's Avatar
You can get custom tunes with the accessport people. It's not just a generic map tool.
I think it's a great device and swapping maps is VERY simple. My issue was that I planned on making changes and $3-400 per retune was out of the question.
I was also able to make modifications to my tune using ATR (AccessTunerRace), which is similar to ECUFlash, but for AccessPorts (although the maps are turned 90*).
So, as to what the products can do... it's pretty similar. One simply costs more money and has a large name company to support it (Cobb) and has fancier hardware.
There's no obvious better choice, but having local support is VERY important IMO. Personally I'm lucky in that I have both Cobb and EvolutionDynamics (KevinD) in my backyard, so I can make a choice.
