Sponsored by:
Sponsored by: CARiD
Clunking sound from passenger side rear
Old Nov 17, 2009 | 09:27 AM
  #46
WickedX1's Avatar
good to recheck upper struts mounts , sway links, and just for kicks look at your springs if any are broken in half, just some pointers
Old Nov 17, 2009 | 09:39 AM
  #47
Webman's Avatar
I have this same noise, but it's very random. Usually only hear it at low speeds. I will have to check those connections when I get my car back.
Old Nov 17, 2009 | 11:34 AM
  #48
senna777's Avatar
Originally Posted by weneversleep
SUCCESS!
It was the strut tower brace bolts. No more clunking.
Hope this saga helps others...
Sure will... I have the same clunk... I'll try fixing it when I'll do my next oil change.
Thanks for sharing.
Old Aug 26, 2010 | 11:27 AM
  #49
CatalystGod's Avatar
Too long since the last post, LOL, sorry about waking up an old thread. looks like I'm just beginning to see this happening from the front passenger side at low speeds, more so when turning. I'm at 36K miles. Lets see what comes out of this.
Old Aug 31, 2010 | 06:40 AM
  #50
Turned out to be the two bolts in the middle of the strut bar were about 1/2 & 3/4 th of a turn loose. Tightened those bishes up and most rattles & clicking noises are gone!
Old Apr 13, 2011 | 11:32 AM
  #51
hoongss's Avatar
I got the same problem too. Gonna fix it tonight and provide an update.
Old Apr 24, 2011 | 04:04 PM
  #52
bong09's Avatar
Hi, well I have had the same sound for almost two years. I took her to the dealership, but they said that is normal noise for the Evo x. It drive me crazy not knowing. So I came a cross this thread today and am going to check every thing listed.
Old Apr 24, 2011 | 06:44 PM
  #53
EvoXFusion's Avatar
maybe rocks got in?
Old Jul 14, 2011 | 01:58 PM
  #54
_Chris_'s Avatar
Has this mystery clunking been solved? For some, it still persist.
I have Hotchkis Sway bars, aftermarket endlinks and coilovers. All seem fine. But clunking still there...hmmmm
Old Mar 2, 2014 | 04:08 PM
  #55
qwertykerr's Avatar
Mine was clunking because of the pass rear upper stablink connection (where it connects to the control arm. The nut was backing off and the connection was loose. Mitsubishi actually missed a washer and that's probably why it became loose. The nut had poor contact because it was a nut designed for a washer.... basically only a thin ring of contact.
The clunking started off here or there. Started happening more and more.
Anyways added a washer, tightened up, and no more clunking.
s2h757
Apr 6, 2017 06:30 AM
aptok14
Jan 27, 2017 06:28 PM
Shadowpriest
20
Feb 16, 2013 11:33 PM
Nasty Evolution
Nov 6, 2011 09:34 AM
redevo58
15
May 2, 2010 10:03 PM
