New stock GSR sputtering at low RPM
Subscribe
May 3, 2010 | 05:23 PM
  #31
Quote: Don't hang out at 2k rpms in 5th gear.
The same thing would happen if you were doing 25 mph in 4th...you're lugging the motor. You are at to high of a gear for the speed.
Reply 0
May 15, 2010 | 03:38 PM
  #32
I don't know if this is the solution to that problem but this is my experience with that. When I first got my car the dealer filled it up with cheap 92 octane Super America gas. Within that first week I noticed that problem. Well not knowing any better I keep using that brand until the BP by my house started carrying 93 octane. Well I switched brands and within a month the problem just went away. I don' t know if its because of the brand or octane rating but one time I was low on gas and there was no BP around so I went to an SA instead. Big mistake because the problem came back. It took another month of using BP for it to go away again. Now I could be going 40 mph in 5th and stepping on the gas with no hesitation at all. Plus the turbo seems to kick in more violently now. But like I said, I don't know if its a solution but all you EVO X owners using BP can comment on that if you want. Hope this helps.Oh by the way, I don't work for BP in case anyone was wondering.
Reply 0
May 16, 2010 | 04:39 AM
  #33
I dont really get gas at BP i get it at country fair but she has never seen anything but 93 in it.
Plan:b - The car does not spudder in any other gear other than 5th. I tried it to see if that was the case. I just bought a HKS Air filter and not it does it even worse.
Reply 0
May 16, 2010 | 08:39 AM
  #34
Guys, there is nothing to fix or cure here. It's most likely a small amount of compressor surge due to the low RPMs (not a lot of pressure), and the partial throttle (BOV partially open). The only way I can see around it would be to find a BOV that opens more easily under lower pressure, but that can cause other problems.
Reply 0
May 16, 2010 | 08:58 AM
  #35
Definitely bogging if you're at 2k rpm in 5th gear.
Reply 0
May 16, 2010 | 10:25 AM
  #36
it does it anywhere between two and three thousand rpms, and only does it in fifth gear. It does like to do it as bad when the a/c is crankin
Reply 0
May 16, 2010 | 10:27 AM
  #37
so every evo X should do this since there is nothing to fix or cure????
Reply 0
May 16, 2010 | 08:36 PM
  #38
My car does not do this any more and I don't think that it's normal if any car does.
Reply 0
May 16, 2010 | 09:04 PM
  #39
Quote: My car does not do this any more and I don't think that it's normal if any car does.
It's compressor surge, which is quite normal for turbo cars, especially in low rpms and partial throttle.
Reply 0
May 18, 2010 | 02:37 PM
  #40
Then why does it only do it in 5th gear and not in any other gear?
Reply 0
May 18, 2010 | 03:15 PM
  #41
Quote: Then why does it only do it in 5th gear and not in any other gear?
I'm not sure why it only happens in 5th gear, but a quick Google search shows that this is common among other cars:
http://www.rmdsm.org/showthread.php?...tch-boost-leak
http://forums.nasioc.com/forums/show...88&postcount=2
http://www.dsmtuners.com/forums/151420670-post14.html
http://forums.tdiclub.com/showthread.php?t=238139
https://www.evolutionm.net/forums/ev...high-gear.html
Reply 0
Subscribe
