Sponsored by:
Sponsored by: CARiD
Parking Brake Not Releasing?
Old Jan 7, 2011 | 09:25 AM
dfissionr's Avatar
So I left the country for little over two weeks and left the evo in underground parking during that time period. The parking stall I'm in has a slight incline so I use my parking brake there. I got back in the evo today and it started but the parking brake wouldn't release.. The handle would come down but I think it's still engaged because the car won't move. I read some stuff about pumping the brakes or letting the car sit idle for a bit but I thought I should also post my problem here for obvious reasons.
Old Jan 7, 2011 | 09:28 AM
evo 9 guy's Avatar
Does it get really cold in said parking garage? It is possible that the E-Brake is frozen if it does.
Old Jan 7, 2011 | 12:01 PM
mlomker's Avatar
The pads/calipers freezing to the rotor seems to be a common problem. Lightly tap the rotor with a rubber mallet and that'll be enough to crack the ice.
Old Jan 7, 2011 | 12:35 PM
dfissionr's Avatar
Thanks for the replies guys.
I don't think it's frozen because although the underground parking isn't heated it doesn't feel cold enough for ice to form. When I went down there it was actually slightly warm. I tried letting my car run idle for about 10-15 minutes as this one tip online said but that didn't anything. There is another one that suggests I turn off the car, stick it in 1st or neutral and pump the brakes. Problem with that tip though is I can't shift into anything when the car is off since I have the MR.
I forgot to mention that the e-brake light will go on and off when moving the handle if that helps diagnosis the problem anymore.
Old Jan 7, 2011 | 12:39 PM
Kracka's Avatar
Push the gas harder, I'm sure it's either frozen or has a bit of rust holding it in place.
Old Jan 7, 2011 | 01:12 PM
iamblue03's Avatar
it's rust. I just returned home after 21 days, and the ebrake was stuck as well. Push the gas a little harder and u'll hear the "snapping sound." It's absolutely normal.
Old Jan 7, 2011 | 01:49 PM
dfissionr's Avatar
Kracka and iamblue03,
It was rust, thanks a ton! I gave it more gas and it made this unpleasant sound but it broke free lol.
evo 9 guy and mlomker,
Thanks for taking the time to offer suggestions.
Old Jan 7, 2011 | 02:26 PM
tehSteve's Avatar
i learned it the hardway 10 stalls later. i ended up rocking the car on my driveway incline with my fatass other than adding more gas or tapping the rotors
Old Jan 7, 2011 | 02:27 PM
evo 9 guy's Avatar
Sorry this made me LOL and now I am getting looked at funny by co-workers.
Redline-Z
Nov 2, 2014 08:21 AM
mnm27mnm
Driving Techniques
156
Apr 2, 2014 09:36 PM
GSRSTIKILR
Dec 14, 2013 02:13 PM
Xtremist
Mar 27, 2009 05:38 PM
Donny510002
Jul 5, 2008 04:32 PM
