problem? need opinions.
I just took my car for a ride after getting it back. Clutch/flywheel. Now it ran good from the place to home. I am out driving around and chilling now and a few minutes ago when it goes to idle it will stay steady at 750 for a few secs then start bouncing from 250/800 or 900 ish. But it drives fine other then the idle. Now its rated for 500 torque and has a 9lb flywheel. Is it just overclutched being stock for now? That's all I can think of. But it doesn't make sense
I also just remembered that it did happen once in my turbo'd rsx. Where I think it may have overboosted and idle bounced. But I shut it off for a bit and it ran perfect and never did it again after. Could that be the issue since the flywheel is so light on a stock ecu
I drove from a parking lot to my grocery store and it started doing it when I stopped to park. Andi drove it like a granny. So its something to do with an overclutched situation???
That's still a few months away unfortunately. Because I want to get all my parts in first. Maybe I need to get things done quicker then I wanted. I wanted to wait until warm weather
no
Congratulations on your perfect idling stock Evo. On both my 2008 GSR and now my 2010 SE the revs jump from time to time while waiting for a stoplight. Could be the ECU adjusting to the load of the aircon compressor kicking in or such, don't know (even in winter the aircon kicks in to keep humidity in the cabin low if you have it on auto). The Cobb AP tune on the GSR helped and soon there will be an AP tune on my SE, too.
Engine overheat with aircon on the recycle mode
My car does something very weird - if I have the aircon on normal fresh air in from outside no problem, the moment I push the recycle button on the aircon the engine temperature gauge goes up/overheat and you cannot switch off the recycle button- the moment you switch off the aircon completely the engine temperature goes down to normal- what is going on? Please help
Doctro X
Oct 31, 2017 01:09 PM
austin_davee
Dec 29, 2016 04:47 AM
