Sponsored by:
Sponsored by: CARiD
Rexpeed dual gauge pod
Old Feb 22, 2011 | 07:43 PM
BaumBizzle's Avatar
If anybody has this (steering column mounted) does it obstruct your view of the speedo? From other pics I've seen I looks as if you can't see the tach till atleast 2k and the speedo until around 60ish. If you had it to do again would you go w/ the same pod or mount'em elsewhere? I'm only gonna run 2 gauges (boost & AFR)....thanks for any input/advice positive or negative
Old Feb 23, 2011 | 06:24 AM
BaumBizzle's Avatar
Ok I guess nobody uses this gauge pod...what would everybody recommend? I like the ATI A pillar but $180ish seems high to just hold the gauges and not really too fond of Rexpeed's 3m tape A Pillar. Soooo whats everybody else running and how do you like it? any regrets?
Old Feb 23, 2011 | 07:02 AM
ZForceX's Avatar
I think you are talking about AMI and yes I have that one. It is worth the money, it will fit right and look right.
Old Feb 23, 2011 | 10:10 AM
HudsonFalcon's Avatar
I'm running AMI and it's definitely worth the price.
Old Feb 23, 2011 | 10:10 PM
zebra4's Avatar
I have the rexspeed 3m tape one and honestly, for the price, it really does fit and work great. It fits nice under the door weatherstripping and looks OEM. All angles match up perfectly.
Old Feb 23, 2011 | 10:32 PM
lucke24's Avatar
Agency Power pod for under the climate control. It comes in 3-52mm or 2-60mm. You would need to add a third gauge (as I did) unless you were ok with running a BS Prosport wideband, or run 60 to 52mm adaptors. But then again, I like stuff to look stock.
Old Feb 23, 2011 | 11:35 PM
Exyia's Avatar
I have the Perrin Double Gauge Pod, and I'm indifferent about it. I think it fits RA's better than Evo's because our gauge needles don't start at the 6oclock position, so the section the gauges blocks fits better
it definitely does block some of the speedo/tach, but not anything important. I'm not a fan of any other gauge position, and sort of liked how the steering column gauges tries to line-up with the tach/speedo. And I'm not a fan of the CF look on the Rexpeed pod, nor am I a fan of obnoxious CF in general
overall though if I had the chance to make the decision again, I would've spent my money elsewhere besides gauges/pods. Just not 100% happy with them, and I know anywhere else I would be less satisfied, but that's just me.
Old Feb 24, 2011 | 03:40 PM
sneaky02's Avatar
any pics of this set up
Old Feb 24, 2011 | 07:25 PM
sun_ice4's Avatar
Are you talking about the Rexspeed A Pillar mount? I have that one, and was disappointed with the fit. Pics are here:
https://www.evolutionm.net/forums/ev...od-w-pics.html
The fact it slides under the trim is nice, but the dash fitment is out a bit.
Old Feb 25, 2011 | 09:24 PM
zebra4's Avatar
PODI Boost Gauge with Rexspeed CF pod w/pics
No that's not the one i have. I bought mine through lancershop.com, and it says made by rexspeed. Mine is dual, and covers the entire A Pillar, and is the same color as OEM interior. No CF. I will get a pic this weekend for you guys.
Old Feb 26, 2011 | 09:40 AM
Mr. Move's Avatar
I was looking at the rexspeed pod but im not a fan of the carbon fiber look. Check out the perrin gauge pod its "adjustable"
Old Feb 26, 2011 | 10:25 AM
luvboost's Avatar
just fab up your own. Way easier/cheaper and it'll give you the power to position the gauges where you want. Here's my temp setup until I mount them in that position.
20$ for both pods and I just trimmed them up to size for the steering column.
Don't be fooled by the picture. I can see anything over 15mph and 500rpm. Those pics are just at the wrong angle.
I thought about the rexpeed but I just didn't feel like paying the price for a pod that I cannot position myself.
there are holes in the bottom of the pods for the wiring also
Old Sep 10, 2011 | 09:07 PM
phishy's Avatar
I would custom make on but I don't know where to start or even how to go about doing it.
WRC-LVR
Apr 12, 2013 07:01 AM
benIX
Aug 12, 2012 08:56 AM
lockadam2112
Jul 14, 2011 03:45 PM
jk_evo8
Jul 13, 2011 07:51 PM
evolness
Aug 23, 2007 04:05 AM
