Sponsored by:
Sponsored by: CARiD
Whats wrong with my ETS Intake install?
Old Aug 12, 2011 | 08:01 PM
phishy's Avatar
I'm getting choppy idle some at times and I can't figure out where the 2nd part of the heat shield bolts up to.
Took some pics of the system and compared it to another members and noticed the filter isn't sitting near the driver headlight.
It's looking like this
MY INSTALL BELOW
COMPARED TO CORRECT WAY
I don't know whats wrong
Old Aug 12, 2011 | 08:05 PM
monkeyfish76's Avatar
It looks like you need to twist it or something. Your angle is off, here is a pic of mine.
Old Aug 12, 2011 | 08:12 PM
phishy's Avatar
I know two hoses are being used incorrectly. The Bend hose is being laid out horizontally and the straight hose is going down vertically to the LICP. So those need to be turned around.
I may have the couplers to the turbo mixed up as well.
I found this as the layout
Old Aug 12, 2011 | 08:23 PM
It looks like you have the hoses switched on the bov but you also need to grab and twist the pipe so the cone angles towards the drivers side.
Old Aug 12, 2011 | 08:28 PM
Hennessy2remedy's Avatar
holy triple sow cow my friend. the closer to your rad fan your intake is (especially without the heat shield) the choppier your idle will be due to the air interferance!
looks like everyone has covered the rest. good luck to you.
Old Aug 12, 2011 | 08:30 PM
phishy's Avatar
Hmm I see what youre saying sorta. So loosen the clamps @ the turbo and twist the pipe?
Old Aug 12, 2011 | 08:31 PM
phishy's Avatar
lol thanks friend, I will try this tomorrow. It's to dark out here to work on this.
Old Aug 12, 2011 | 08:38 PM
Yes, the bung going to the bov should be strait and level. The way your pipe is sitting the bung is angled up towards your hood.
Old Aug 13, 2011 | 04:13 PM
phishy's Avatar
All fix'd up thanks. Idle is fine and shield is on. Also reset ecu and let it idle for 10 mins with and without ac on.
Old Aug 13, 2011 | 04:53 PM
Awesome, glad it worked out
Old Aug 13, 2011 | 08:47 PM
ProjectGSX's Avatar
Put the heat shield on. In order for the shield to fit you will need to orientate the pipes correctly. This will solve your problem.
EGbeater
Jul 23, 2016 08:16 AM
Kreeker
Jan 4, 2014 04:52 PM
Kidloco51
Jan 11, 2013 09:18 PM
BlackTrack
Aug 29, 2012 01:48 PM
CBRD
Feb 7, 2011 12:54 PM
