Sponsored by:
Sponsored by: CARiD
HeadStuds 4 reassurance on stock block?
Old Nov 9, 2011 | 08:35 PM
tehSteve's Avatar
Question HeadStuds 4 reassurance on stock block?
Good dayfrom Antarctica. Don't ask what I am doing here. All I can say is thank God for Remote Desktop. When I get back I plan to be one step closer to my turbo build while hoping to maintain my stock block. I plan on taking the ride to the shop to get my fuel & injectors scaled / installed. One step closer. Turbo I will be running will either be a green, map, or a red tuned for a daily driver setup and plan on keeping around 380 torque as recommended. My question is that if I plan on never "building" my stock block, do you think it is worth it to install ARP headstuds as "re-assurance". In two years of driving I only threw it from 4th redline to 3rd redline once on accident Should I do the studs or pass because it really isn't worth it till I increase the torque passed the so called "safe zone" & build up the block? (hope I never do so) Cheers and I hope the weather is much warmer up there!
Old Nov 10, 2011 | 02:56 AM
Zombie Killer's Avatar
Interesting idea. I think its a good idea but I'm no guru. Just dont do it as a "mod" and rely on it like a built motor.
Why are you in Antarctica?
Old Nov 10, 2011 | 04:50 AM
Frew's Avatar
Imo if you are going in the motor to do only that, don't do it
Old Nov 10, 2011 | 04:53 AM
Robevo RS's Avatar
No its not.
Change rods , that is your safety insurance. But when you do that it makes sence to do piston and headstud etc. Since you are opened up the engine anyway.
Old Nov 10, 2011 | 04:56 AM
Robevo RS's Avatar
If you go with highher boost then stock. RPM is not as much of the factor on this , then a boost itself.
Old Nov 10, 2011 | 05:38 AM
tehSteve's Avatar
Thanks for the advice. I am in Delphia oceanport and it is beautiful. The bays are blue the landscape is amazing, but it is quite a bit cold. I'm here on vacation because I wanted something out of the ordinary and thought that Antarctica was all ice. Also I am an IT major and the programming scene here is very rich in culture
Old Nov 10, 2011 | 05:46 AM
Dude, very cool. Way to think outside the box.
Old Nov 10, 2011 | 05:49 AM
Kracka's Avatar
No kidding
Headstuds are not needed on the stock block, chances are you'll break something else before the studs/headgasket let go.
Old Nov 10, 2011 | 05:57 AM
boostedtres's Avatar
wow schaaaaweeeet vacay. whats the temp like? how you holding up with the daylight/night time hours? cool times. make sure to take a bunch of pics, i, for one, would be stoked to see them when your back.
headstuds, IMO, are one of those things that is el cheapo insurance for our motors. cheaper to have them in than to separate the head. that being said, like above posters said, your rods etc are way more likely to go first. so unless your in there for some other reason (cams, pistons, rods) I would wait till you mod list gets bigger and they get tossed in with other stuff.
i know this is not the case, but all i can think about it hundreds of miles worth of ice, studded tires, penguins instead of cones, ripping the evo around!!! if only right?
Old Nov 10, 2011 | 06:04 AM
ugakirk's Avatar
EVOlutionary
Oct 15, 2017 04:11 PM
Evo-IXse06
32
Aug 13, 2016 09:55 PM
TURBO_S2K
32
Dec 26, 2013 01:18 PM
Nelson999
35
Jul 25, 2012 03:06 PM
mindovaanything
Sep 10, 2011 02:48 AM
