Sponsored by:
Sponsored by: CARiD
does anyone have a Shep final drive
Old May 9, 2012 | 06:43 AM
2003evo8's Avatar
Hello just wanted to see if anyone has a Shep final drive in there evo x. i have one installed in my x(they sell a 4.28, but i got a newer version 4.30) it is great for longer gears, cruising, and better gas milage around 270 highway per tank on race gas map! but the issue i want to see if anyone else is having is at the strip, launching car and shifting to 2nd, the gears are so long and drop rpms and loses all boost....... is anyone else have this issue, and if yes what have you done to correct this issue or should i just take it back out and sell it.
Old May 9, 2012 | 10:03 AM
TheBlade's Avatar
your problem sounds logical. I hate how short the gearing is and wanted the shep setup myself.
My thought to fix the problem though is, build your top end, and run the car to higher revs so when you shift you can keep it in boost.
Old May 9, 2012 | 10:20 AM
EVOX_Ryan's Avatar
Here is some good info:
https://www.evolutionm.net/forums/ev...t-not-dos.html
I would imagine it would probably be worth it for a really high horse power stroker engine.
Like TheBlade says, on a built non-stroked setup the consensus is you are better off reving it out. 9k!
Old May 9, 2012 | 07:08 PM
Johnr352's Avatar
Boy, I want this with his shorter 5th too.
bwanner
38
Jan 10, 2022 11:38 AM
MagicManRed
596
Dec 9, 2020 07:59 AM
chronohunter
16
Mar 29, 2016 06:12 PM
Kraise
Oct 30, 2015 02:35 PM
evo05VIII
13
Mar 6, 2009 03:47 PM
