Sponsored by:
Sponsored by: CARiD
key battery died
Old Jul 16, 2012 | 07:26 PM
No Goal Nicolas's Avatar
key battery died
Hello everyone so as stated above the battery in my FAST key died. I had an extra key but it got lost when I gave it to my parents. I replaced the battery and the FAST does not work. When I take off the plastic cap on the steering wheel and insert the actual key it will not start. The dash displays 'KEY MISSING' or something along those lines. I have read the manual enough times I could recite it on spot. Do I really have to go to the dealer and have the key/car programed? Does anyone know of a way to avoid this? I know this sounds sketchy but it really is my car, look at my post history. 2008 GSR its blue and it is all mine since I picked it up with 7mi on the dash. Any help would be huge.
Old Jul 16, 2012 | 07:32 PM
sith_killer_99's Avatar
Odd, I had to replace the battery in my FAST key for my '09 Ralliart. I went to Walmart, bought the replacement battery, switched it out, and it was fine. It didn't have to be reprogrammed by the dealer.
Sounds like there may be a bigger problem than just the battery.
Old Jul 16, 2012 | 07:35 PM
ravenjam's Avatar
It should work. I have replaced the batteries in both my keys and I did not do anything special to get them working again. Check if you inserted the battery correctly. Do you get a light when a button is pressed?
Old Jul 16, 2012 | 07:55 PM
xi's Avatar
xi
+1
I know it sounds stupid, but make sure it's not in there upside down...
Old Jul 17, 2012 | 08:39 AM
dyss.'s Avatar
How long was the key dead for? you could have zeroed out the info, thus having to get it reprogrammed.
Old Jul 17, 2012 | 09:06 AM
TheBlade's Avatar
when you insert the key into the ignition you know you need to hold the keyfob to the base of the key piece right?
I would try a different battery. Maybe you have the wrong one, or one without enough juice even though it's new
Old Jul 17, 2012 | 09:36 AM
efinirx8's Avatar
Maybe the battery in the key fob never died and what happen was your FAST key got erased. There's a recall on the older keys where cell phones can erase the programming on the key.
Old Jul 17, 2012 | 10:19 AM
ugakirk's Avatar
I replaced my batteries no problem.
Like Blade said, you know you have to slide the end of the key fob over/onto the end of the key when you stick the metal key in the ignition right?
Old Aug 4, 2012 | 02:06 AM
evo9ferio's Avatar
dammm that sucks~!!!
ApolloX
May 29, 2015 07:25 PM
linjy2
Dec 26, 2014 01:38 PM
live2teach
Jul 15, 2014 05:22 PM
WarmMilk
Feb 5, 2014 06:29 PM
Johnr352
Mar 5, 2011 05:24 AM
