Sponsored by:
Sponsored by: CARiD
Need a straight answer about bolt ons.
Old Aug 29, 2012 | 08:52 AM
fimer's Avatar
good information.
Old Aug 30, 2012 | 07:15 AM
europe4life's Avatar
Get the Cobb Accessport and make sure when you get the car professionally tuned that they put the map into the device
Old Aug 30, 2012 | 08:40 AM
tonerockyhorror's Avatar
You could run the intake if you also have a Cobb AP. It depends on the intake, but they have a base map for the more popular intakes for Stage 1 and Stage 2.
Old Aug 30, 2012 | 09:05 AM
TheBlade's Avatar
Originally Posted by Snakes709
Install everything except the intake. The bigger maf housing with throw your afr and few trims way off, not mention boost. Also the tp will se the cel off due to no cat.
Just get an intake with an OE sized maf housing like;
ETS, AMS, K&N, Injen, etc.
No Tune:
-OE maf'd intake
-Upper and Lower IC pipe
-DP (no external dump) (not worth it unless you're swapping turbo though)
-FMIC
-CBE
w/ Tune:
-TP
-3port
-Turbo/Manifold
-Cams (headwork)
Once you have a tune, consult your tuner before making any changes.
Old Aug 30, 2012 | 04:16 PM
jesseanson's Avatar
Yeah your deff gunna need a tune after those parts my car ran like **** after pretty much the same parts until I got a tune
Old Sep 29, 2012 | 05:19 PM
fnlygotboost's Avatar
install and tune at the same time, best bet to be safe
Old Oct 3, 2012 | 06:11 PM
BuseRockS's Avatar
_______
how much does a tune go for?
Old Oct 3, 2012 | 07:59 PM
TheBlade's Avatar
It varies a lot shop to shop, tuner to tuner. I know my tuner has done a few e-tunes for people that have widebands, so I'm not just going to say what I paid. But I definitely felt like I got an amazing homey-hook-up when I've heard what some other places charge.
The value of cost to amount of time he spent, and the help with installing the 3port in the dark in a parking lot, is just unmeasurable.
Old Oct 4, 2012 | 05:52 AM
Dalek's Avatar
Tuning is the key. Be sure the tuner has a dyno to verify your HP and Tourque outputs.
Old Oct 4, 2012 | 09:15 AM
ETS Michael's Avatar
We had good success with just bolt on's and no tune on the X.
Check out this post.
https://www.evolutionm.net/forums/ev...ts-thread.html
This test was done on our 08 GSR.
Thanks!
Michael
Old Oct 4, 2012 | 09:26 AM
TheBlade's Avatar
Verifying HP and Trq is totally a moot point, because dyno's read different and other variables come into play anyhow.
I'm not saying dyno-tuning is bad in anyway, because the dyno is a safe environment to put power down rather than a public road for sure.
But, I am saying, if the tuner is verifying that fuel trims are good, timing is working as it should, boost control looks proper and the resulting AFRs are good and everything is driving well. No problems with tip-in and what not, that is what matters. Whether, it's a road tune or dyno tune it doesn't matter. Just be safe if you're going to road tune and datalog.
The power will always be the result of good tuning, but it's not what's important with having a good tune.
Old Oct 13, 2012 | 01:49 PM
lavar56olb's Avatar
Originally Posted by Nasty661X
So even just casual driving would be too lean with these mods? I just can't wait to get it tuned. Still undecided where to but hopefully soon.
YES YOU CAN HAVE IT ON, I HAD COBB SF INTAKE, TP, DP AND SINGLE EXIT EXHAUST, AMS FMIC AND UPPER PIPING WITHOUT TUNE, JUST DONT GO INTO BOOST.
mygsr
Mar 20, 2013 11:08 PM
08bluegts1
Lancer Engine Management / Tuning Forums
Apr 8, 2011 08:15 PM
black95tt
Jan 10, 2011 08:48 AM
YShen15118
Apr 26, 2010 09:53 AM
funkad3llic
Jun 22, 2007 02:06 PM
