Sponsored by:
Sponsored by: CARiD
How to make the shifter better?
Old Sep 3, 2012 | 09:13 AM
AGinHD's Avatar
Hey guys so I have had my evo gsr for just over 2 months now and to tell you the truth I'm not the biggest fan of the shifter. I was just hoping to get some imput on what people are running out there as far as new weighted shift knobs, short shifter and bushings go. I'm really just daily driving the car with a few pulls from here and there. Any info or pictures showing off their setup would be great! Thanks
Old Sep 3, 2012 | 09:23 AM
evokerfes's Avatar
Get a weighted shift knob, do a short shifter to get rid of the long throws, get the underhood, gate selector, and shifter base bushings.
Change the transmission fluid to 2x MTL and 1x MT90
How many miles do you have on your car? As the car ages, your shifter will become more smother.
Old Sep 3, 2012 | 09:36 AM
AGinHD's Avatar
I have just over 2000 KMS lol
Can you reccomend any brands? I know that for my old rsx type s I had a skunk2 shift knob and a buddy club short shifter with buddy club bushings. I liked that setup but I don't know what would be comparible for the evo
Old Sep 3, 2012 | 09:37 AM
Sev's Avatar
Sev
TWM sells pretty good weighted knobs and bushings.
Old Sep 3, 2012 | 10:00 AM
The Unknown's Avatar
All I did was pick up the Cobb double adjustable short shifter... I don't notice anything. I am still going to keep using it , I'm just like "meh". I DD and mess around here and there.
Old Sep 3, 2012 | 10:01 AM
evokerfes's Avatar
https://www.evolutionm.net/forums/ve...led-evo-x.html
Works makes good bushings. TWM makes good shift knobs but they're pricy. I like the Blox 490 shift knob. TWM and Works both make great short shifter, but I prefer the Works. Kracka had both the TWM and Works short shifter and he preferred the Works short shifter as well
https://www.evolutionm.net/forums/ve...t-shifter.html
The transmission fluid brand is Redline.
As you rack up the miles on your car, your car will shift better.
Old Sep 3, 2012 | 10:59 AM
MisterHappy's Avatar
Running a torque soultions short throw, did the trick for me.
Old Sep 3, 2012 | 11:01 AM
AGinHD's Avatar
Wow awesome links! Thank you very much! I read his whole review and am kind of leaning towards the works lol
Old Sep 3, 2012 | 11:14 AM
evokerfes's Avatar
Yeah, because of his review I went with the Works short throw shifter. For the underhood bushings and shifter base bushings, I went with AMS because I prefer the metal bushings. Something to note: when you're ordering the underhood bushings, 2008 and 2010 have different bushings. The 2010 bushings are much larger. I believe 2010+ use larger bushings
Old Sep 3, 2012 | 11:36 AM
AGinHD's Avatar
Yeah I found this kit and I think I'll just grab this?- http://store.worksmotorsports.com/WO...03_642.104.htm
It seems like it comes with everything I would need
Old Sep 3, 2012 | 01:58 PM
thegoodservant's Avatar
The X shifter is miles ahead of the VIII but on the VIII I had I used torque solution solid bushings on the the base and the linkage and it made a huge difference in the notchyness of the shifter. The X shifter doesn't bother me at all.
Old Sep 3, 2012 | 02:01 PM
SamsonEvoX's Avatar
I have a Torque Solutions SS and TWM full bushing kit. Made a world of difference. I am also running an AMS Delrin shift knob. The car is so much easier to drive and makes speed shifting less clunky. My son is running a Works SS and full TWM bushings and his too is simply amazing, both in normal driving and banging off shifts at redline. He has a bunch of shift knobs from Cobb to Mitsubishi aluminum to TWM Abrams. They all work nicely.
Old Sep 3, 2012 | 02:08 PM
evokerfes's Avatar
Yeah, that package is good. I probably would've gone with that if I didn't buy everything seperately
If you want to make it a little bit more complete, you should get this:
http://www.amsperformance.com/cart/a...shing-kit.html
After installing it, I could "feel" the gates more. It added a more positive feel to the shifter.
Some people experience lockouts or notchiness when going WOT and shifting. A stiffer front motor mount will help with that. I have one installed in my car and it makes WOT shifting buttery smooth. However, it will add cabin vibrations and you will especially feel it when you run AC. I use the 70A durometer AMS front motor mount.
http://www.amsperformance.com/cart/A...e-Pressed.html
If you want to tighten up the shifter even more, you can get the TWM cage for the Evo X. I don't have it installed on my car nor do I feel it's necessary for daily driving
http://www.twmperformance.com/shorts...rtshifters.htm
Old Sep 3, 2012 | 02:10 PM
quicksevo's Avatar
Blox weighted shift knob, works bushings and t1r shifter helped a lot for me
Old Sep 3, 2012 | 02:19 PM
evokerfes's Avatar
Yeah the Blox 490 is a great shift knob that is heavy and is more affordable.
