Sponsored by:
Sponsored by: CARiD
Brake Failure
Old Sep 20, 2012 | 10:19 PM
ap2012's Avatar
Brake Failure
My brakes completely stopped working on the freeway a couple days ago. I was going around 90 and let off the gas. Something weird went on with the revs and they kind of went crazy on their own. Then my brake pedal went stiff and I had to e brake to a gas station. Whenever I tried starting it again the revs shot back and forth from 1-3k until the car died. I'm wondering if anyone has experienced similar problems? My car is in the shop right now and I don't know what's wrong with it yet. The car is completely stock.
Old Sep 21, 2012 | 06:22 AM
eggiez's Avatar
Did you buy used? Could it have been returned to stock with a **** tune on it?
Old Sep 21, 2012 | 06:28 AM
MuslimEvoFreak's Avatar
Is there a limp mode on the Xs? I know my minivan did the same thing you described when the factory tune was tampered with. It went into limp mode. I sent the ecu out to get it re-programmed and it never happened again.
Old Sep 21, 2012 | 07:39 AM
TheBlade's Avatar
With the revs shooting up I'm thinking it's not a brake issue but a clutch/trans issue. I'm thinking this because it's your brake fluid that's used to actuate your clutch via CMC, which is known for failures.
Do you have leaking fluid?
Old Sep 21, 2012 | 07:54 AM
Iowa999's Avatar
Sounds like the hose between the intake and the brake-booster to me. It either came off or the one-way check-valve blew.
Old Sep 21, 2012 | 08:44 AM
TheBlade's Avatar
Good point, instant stiff brake pedal
Old Sep 21, 2012 | 05:39 PM
ap2012's Avatar
Bought it new a few years ago so no tune. I think it's in pieces at the shop now.
Old Sep 21, 2012 | 05:40 PM
ap2012's Avatar
No leaking fluid that I know of. I checked for that when I pulled over. It could have been a slow leak.
sabotaaage
Sep 22, 2022 01:47 PM
StancedEvoX23
47
Sep 7, 2013 06:49 PM
RalliMark
Mitsubishi TC-SST Discussion
Apr 10, 2013 08:58 PM
hxc chris
18
Apr 3, 2010 07:11 PM
usacchamp
AEM EMS
13
Aug 22, 2006 07:26 AM
