Sponsored by:
Sponsored by: CARiD
TialQR spring assistance
Old Sep 27, 2012 | 09:14 PM
tehSteve's Avatar
Hi everyone. I was lucky enough to pickup a flanged AMS licp and will be throwing on a TialQR since my Synapse Synchronic wasn't playing nice even with the aby.milspec spring. I did some research on the spring that comes with it and noticed is was -11. I'm pretty sure this is also the same spring type that ships with a brand new ams piece with the QR already on it. I've read that I should change to the -6 spring because of flutter/surge. I will be retuning immediately, but was wondering if I should stay with the -11 or just go with -6. Would AMS have already done the spring swap if it really needed to be changed?
Old Sep 27, 2012 | 09:44 PM
genelee112601's Avatar
Sup Bro!
im on AMS LICP with QR on 6psi Spring
already Tuned, No Fluttering!!
love my set-up!
Old Sep 27, 2012 | 09:54 PM
tehSteve's Avatar
Does it it make a high pitched whistling sound when you just press the gas very slightly?
Not the turbo whistling spool sound, but like a high pitched leak lol.
Old Sep 27, 2012 | 09:58 PM
tscompusa's Avatar
choose your spring pressure based on the vacuum at idle.. if you choose to stiff of a spring it will stay open and whistle like you just said above..
what vacuum are you producing at idle?
Old Sep 27, 2012 | 09:59 PM
Snakes709's Avatar
I have the same bov, mine came with a -11psi spring but i installed a -8psi which was still abit to stiff so i went to a -6psi spring and works perfect. Here is a video with the 8psi spring. The first video around the 4:38 mark (during one of the turns) you can hear it flutter.
Old Sep 27, 2012 | 10:13 PM
tehSteve's Avatar
Hmmm. You and Wraith seem to be on the same page.
It does say to chose by vacuum though >_<
Your 2nd video is 8spring as well? Sounds good.
Old Sep 28, 2012 | 07:14 AM
Snakes709's Avatar
Wraith went with 6psi right off the bat. I decided to try the 8psi but after a few weeks i switched to the 6psi spring and it works perfect. Both videos are with the 8psi spring.
Old Sep 30, 2012 | 07:08 AM
nastorino's Avatar
Crap mine came with a -10
where the hell can I order a -6 from? I need it my friday the latest, my tune is on the 13th.
Old Sep 30, 2012 | 09:18 AM
Snakes709's Avatar
ams sells them
Old Oct 4, 2012 | 09:27 AM
ETS Michael's Avatar
TiAL will swap them out for free. If you need something quick we can get you one.
Michael
AcePitcher11
20
Oct 9, 2016 11:20 PM
Shane Anderson
Feb 4, 2014 02:15 PM
deegaw11
Oct 10, 2006 05:19 PM
JoeA
11
Sep 22, 2005 07:03 AM
CBG
16
Sep 9, 2004 12:33 PM
