Sponsored by:
Sponsored by: CARiD
How much tuning can effect fuel economy?
Old Dec 16, 2012 | 09:58 PM
CrossRifles's Avatar
Question, what is your personal fuel economy like for your Evo X after being tuned?
Just curious on what it will be like. Does it drastically change MPG?
Old Dec 16, 2012 | 10:24 PM
Johnr352's Avatar
It can. Depends on several factors but, usually mpg will improve a bit, as you'll be tuned a bit leaner. We have a few different maps for different tracks and exhausts and, as the AFR changes a bit with these tunes, so does the burn rate.
Old Dec 17, 2012 | 07:17 AM
TheBlade's Avatar
Pre-tune / post-tune my mixed driving average is only changed by .5-1mpg
However, when my X was new and untuned I would see city around 15-16mpg and now I see 17-18 more frequently.
Old Dec 17, 2012 | 07:59 AM
GsrJake's Avatar
I get 21mpg city driving normal. 26mpg highway after my tune
Old Dec 17, 2012 | 12:13 PM
acidtonic's Avatar
Depends on how much the tune changes, but generally people see better mileage.
It changes more for 08 users since their stock tune was less optimized for mileage.
My 2012 rom almost looked tuned already at first glance. The 0-100 load area is already quite dialed in with regards to fuel economy.
Those same changes on the 08 would show some gain.
Old Dec 17, 2012 | 04:03 PM
ugakirk's Avatar
Usually 2-3. If you have an 2008 maybe even 5.
Old Dec 17, 2012 | 04:50 PM
flipflop's Avatar
MPG from my stock tune vs Pro tune was about 4 mpg... favoring the Pro tune map. I was using an mobile application, forgot what it was called, to get true MPG... But I drove like a grandma, not fun. MPGs on our cars are still pretty Sh**ty
Last time I spoke to my tuner, you can run 2 maps... one "perfomance map" and "economy map". How much more economical, I have no idea. Is it worth it?! Tuning fees, Time, etc. vs Gas savings... You can probably get your ROI after a couple of years
Old Dec 18, 2012 | 10:10 AM
CainEvoX's Avatar
have to keep your foot out of it for economy. I didn't buy an evo for the gas mileage though. get a DD
Posted from Evolutionm.net App for Android
Old Dec 18, 2012 | 10:49 AM
acm_evo's Avatar
What? Surely you jest...
Either that, or you drive like a Chinese 80 year-old...
Old Dec 18, 2012 | 12:17 PM
Wicked_White10's Avatar
Lol I can't believe this. I shift at 3k when I'm just driving normally..stay out of boost and don't get 21 in the city. You must be grannying more than I am
Old Dec 18, 2012 | 12:36 PM
Kracka's Avatar
My MPG has stayed practically the same all the way from new to modified. I generally average 18-20 MPG in my daily mixed driving, and 22-26 MPG on the highway depending on speed.
Stock or modified, the best way to save gas is stay out of boost, but what fun is that
Old Dec 18, 2012 | 04:16 PM
Cellar Door's Avatar
Keeping it light on the gas pedal is key with every car, a lot of people forget this is a 3500-3600lbs car plus driver, fluids.
This might sound silly but I have done this with all my previous cars. I never fill up past 1/2 of the tank. Its less weight you lug around and fuel is heavy. Granted you need to stop at the pump more often, I don't mind.
The fuel economy is right on the button (AWD, turbo, heavy car). Another thing I do is I throw it into neutral every chance I get when going down a longer steady hill, that I know it is safe to not be in a gear.
Did that with my 1g and 2g dsm and it worked very well. Also be mindful of how much the engine is struggling. Use the gearing to its advantage, for ex. if you floor it in 5th and you are doing 20, you are not going to go anywhere but the ecu will be injecting 100% fuel it can at that point. In 3rd you will only need 25% throttle briefly, sure the higher RPM offsets some of the gains but it works.
Old Dec 18, 2012 | 10:43 PM
Windforce18's Avatar
Pre-tune I usually get around 17 city/21 hwy, maybe about .5-1 mpg better after tune.
Old Dec 18, 2012 | 10:52 PM
chinoxmk22's Avatar
thats what I'd like to know
Seifer780
Oct 7, 2011 05:59 AM
EvoPower81
Oct 6, 2010 12:20 AM
780
21
Dec 15, 2009 07:12 AM
CrackerJackToy
Jun 26, 2008 05:27 AM
radicaledward
Lancer Engine Tech
26
Jun 14, 2007 08:46 PM
