Sponsored by:
Sponsored by: CARiD
My buddy's X is dead, sad face
Old Feb 7, 2013 | 06:46 AM
  #46
ugakirk's Avatar
Yea, its hard sometimes to get them to warranty anything.. much less a modded and tuned car..
The mods aren't really the deal breaker.. Once you tune it the engine warranty is gone.. Which is what you are going to need..
Old Feb 7, 2013 | 06:48 AM
  #47
Dynotech Tuning's Avatar
Chances are that Kaizen did a good job on the tuning. They do quite a few X's and have a good reputation. Just talk to Scott about finding the cause. It will help everyone in the community because this is a strange engine failure. Its going to be expensive! They are good people and are not in business to screw anyone. Good luck!
-Brian
Old Feb 7, 2013 | 06:50 AM
  #48
CaptainAsia's Avatar
Figured as much, I need to check mine now so my Evo doesn't blow up...
Old Feb 7, 2013 | 06:51 AM
  #49
AWDTerror's Avatar
Originally Posted by CaptainAsia
Quick question, let's say it was the relays that cause it to blow, (putting on the flame suit and throwing the hail mary haha) would the Mitsubishi warranty pay for it?
In addition to what other's have said, there were TSBs that were out for replacing relays in wintery areas, and ultimately, regardless of how unrelated it was to the climate, Mitsubishi, has, and will use that to nullify any claims of faulty relays.
But it doesn't hurt to try.
Old Feb 7, 2013 | 07:01 AM
  #50
Sharkbite2000's Avatar
Hmmm.
Old Feb 7, 2013 | 07:18 AM
  #51
vegittoss15's Avatar
Originally Posted by AWDTerror
So let me get this straight, the 378tq, the drag racing, and the time attacks had nothing at all to do with you loosing a valve?
While I agree that your tune was probably ****, by your statement above, neither of you knew what you were doing, so your just as much at fault as he was. Regardless, your tune wasn't the sole reason your motor dropped a valve, so stop trying to say it was.
Pardon my ignorance, but what exactly would torque have to do with hurting/dropping a valve?
Old Feb 7, 2013 | 07:20 AM
  #52
Dammit, I'm at 68k pretty sure I can get my relays switch over without paying...
Old Feb 7, 2013 | 07:29 AM
  #53
AWDTerror's Avatar
I meant to put the hp and the tq figure to show that he was pushing the limits of the stock block as is.
To answer your question though, nothing. Valve damage is usually a result of something timing related (timing belt/chain breaking/non-interference head), FOD, improper installation, or knock.
Old Feb 7, 2013 | 07:31 AM
  #54
AWDTerror's Avatar
Look up the TSB (probably a good idea to print and take with you) and then just say you have difficulty starting when it's real cold out, or whatever the TSB says the symptoms are and you should be taken care of. It's what I did and they switched me out to the, at the time new blue relays.
Old Feb 7, 2013 | 07:59 AM
  #55
Alpha X's Avatar
Keep this thread on topic please.
If you want to argue with each other take it to PM's.
Old Feb 7, 2013 | 09:35 AM
  #56
For free?
Old Feb 7, 2013 | 09:47 AM
  #57
AWDTerror's Avatar
Yes, TSBs are similar to recalls, but not mandated, and dealers only consider them if you are exhibiting the "symptoms".
Old Feb 7, 2013 | 09:49 AM
  #58
Also I believe I'm over my warranty with the milage I have
Old Feb 7, 2013 | 10:07 AM
  #59
AWDTerror's Avatar
Doesn't hurt to go in an check. Mine were replaced outside of warranty even though they didn't have to.
Old Feb 7, 2013 | 10:25 AM
  #60
meffie's Avatar
TSB's don't fall under warranty
