Sponsored by:
Sponsored by: CARiD
For those of you with ACD pump failures (merged)
Old Mar 5, 2014 | 12:20 AM
  #271
coryl's Avatar
Relocation kits are ready for the 2008+ Evo X and Rallliarts...they look absolutely awesome even better than I could have expected....the boot space looks stock! I just got all the step by step pics and will post them Friday when I have a moment.
Old Mar 5, 2014 | 03:54 AM
  #272
Thomar's Avatar
How noisy is the pump in the trunk?
Old Mar 5, 2014 | 04:42 AM
  #273
ChUt26's Avatar
Is putting the pump in the trunk going to be okay keeping it cool?
Old Mar 5, 2014 | 05:04 AM
  #274
samuel1986's Avatar
Put in my two cents!
Have just sent my complaint in. Made sure I posted on the complaint site about the ACD pump, Timing chain, and the piece of crap fuel relay where the timing chain and fuel relay both got an updated part yet not recalled Bulls***.
Old Mar 5, 2014 | 05:11 AM
  #275
ignitionr34's Avatar
Sweeet! Been waiting for this!
Old Mar 5, 2014 | 08:26 AM
  #276
coryl's Avatar
The pump only turns on briefly and you shouldn't hear anything from the trunk.
Old Mar 5, 2014 | 08:41 AM
  #277
coryl's Avatar
The pump doesn't need to be kept cool, in fact it makes the pump have to work harder...never heard of any problems relocating and don't perceive having any.
Old Mar 5, 2014 | 08:52 AM
  #278
coryl's Avatar
I have negotiated for a discount deal for the first of us bunch, 15%-off, plus I have arranged for the best mechanic around to do the installs here in Ottawa at Rodgersperformance.ca, and I've also arranged to have the dealership bleed the lines at a discount. You aren't too far from Ottawa, so you could maybe even make the drive down here where everything's been set up already.
Old Mar 5, 2014 | 09:00 AM
  #279
coryl's Avatar
The finished look...
Attached Thumbnails For those of you with ACD pump failures (merged)-acd.jpg
Old Mar 5, 2014 | 09:03 AM
  #280
adamsheehy's Avatar
Is this based upon knowing the actual temperature tolerances or just speculation? These pumps have failed during both mild and hot temperatures.
Old Mar 5, 2014 | 09:07 AM
  #281
coryl's Avatar
Some more pics of relocation...
Old Mar 5, 2014 | 09:16 AM
  #282
coryl's Avatar
More pics...
Old Mar 5, 2014 | 09:33 AM
  #283
coryl's Avatar
More pics...
Old Mar 5, 2014 | 09:54 AM
  #284
coryl's Avatar
Not based on speculation at all. The pumps fail not because of the hot or cold temperatures, but because the pumps have been damaged by corrosion sitting underneath the car unprotected. During hot weather the fluid therefore is thinner and leaks out the damaged pump, and in cold weather the pump has to work harder to push the thicker fluid and since the pump is damaged, you get your dash lights and codes with pump failure.
Old Mar 6, 2014 | 05:47 AM
  #285
samuel1986's Avatar
It IS due to cold weather. Had mine go bad and the dealer told me it was due to the fact the cold weather gels up the oil inside making it thicker. It causes the pump to work ALOT harder than normal and ends up frying the motor of the AWC pump. All it does without the pump is it takes away the functions to change it from snow, tarmac, and gravel. Basically makes it an open diff AWD. They will not make it a recall due to the fact that in the southern warmer states they aren't having the issues. Just in the north.
