Sponsored by:
Sponsored by: CARiD
Just got a TBE, tune question
Old Aug 13, 2013 | 06:25 AM
GSRwithRotas's Avatar
No, a stock car doesn't have switchable maps. But you can get your tuner to put on multiple maps on your car. It might be the cruise control switch, I have never used it, just talked about it with some guys at a shop one day after they tuned my car up in NC. I thought they said that I could do it with my S-AWC switch but I could be wrong.
Old Aug 13, 2013 | 10:26 AM
trick3d's Avatar
Its the Cruise control button.
Old Aug 13, 2013 | 11:03 AM
Iowa999's Avatar
Good answer.
Last edited by Iowa999; Aug 13, 2013 at 11:23 AM. Reason: original version was too obnoxious
Old Aug 14, 2013 | 08:08 PM
m0nkie's Avatar
hey guys. I encountered another problem. Please see if you know what might have caused this.
I got the Cobb AP and downloaded the stage 2 map. Stock Intake and Turbo back exhaust. Car runs smoother and I got rid of the early RPM jerking feel..
However, when I go WOT, the RPM starts acting weird at 6000rpm. It looks like it's not getting to 7000. I can see the RPM arrow fluctuate up and down around 6000 - 6500.. then the car's warning sign goes on and ASC turns off. The car display the no traction yellow warning. I have to restart the car for it go to away. This happens on WOT only. When i slowly hit the gas, RPM is very smooth while shifting at red line. But when I floor it, RPM doesn't seem to hit 7000..
A friend suggested I should change my 5 years old spark plugs. Any other recommendations? Anything I can Data Log on the Cobb to monitor this?
thank you
Old Aug 15, 2013 | 05:37 AM
Kendogg's Avatar
Not sure if that will solve your issue but I would recommend doing that anyways
Old Aug 15, 2013 | 08:46 AM
Iowa999's Avatar
Over-boosting and/or hose to FPR came off.
Old Aug 15, 2013 | 09:14 AM
m0nkie's Avatar
Is this the FPR? my 08 seems to come with zipties
Old Aug 15, 2013 | 09:28 AM
Kendogg's Avatar
Yep, thats it. The previous owner already zip tied it for you
Old Aug 15, 2013 | 10:57 AM
m0nkie's Avatar
what would you recommend? Kind of scared to drive it if it's over boosting.
I'm running the Normal Wastegate Stage2 91 Octane. Just realized I really should use the Stage2 ACN91 Octane since I'm running on Cali gas.
should I switch to the Low Wastegate - For vehicles exceeding target boost? Or should I get a pro tune to solve this issue?
Old Aug 15, 2013 | 12:39 PM
Iowa999's Avatar
Check to see if the hose to FPR is still there. Zip-tie, if it isn't already. And start reading up on over-boosting with Cobb Stage 2 and an exhaust that flows too well. I found about 10 threads on it.
austin_davee
Jul 6, 2016 07:30 PM
Socaloc
Nov 16, 2013 04:17 PM
turbosuckout
30
Dec 5, 2011 06:54 AM
Ladogaboy
Oct 10, 2011 08:31 AM
rawburt
E85 / Ethanol
Jan 26, 2009 11:28 AM
