Sponsored by:
Sponsored by: CARiD
noob question on intake
Old Jan 3, 2014 | 08:54 AM
Evo82's Avatar
ok i will look it to them...thanks
Old Jan 3, 2014 | 08:58 AM
Fotown's Avatar
Originally Posted by sc@motovicity
Pure Tuning, Toledo OH
+1, I have used Pure Tuning for my DSM, my Subaru, and will again for my future evo, very knowledgeable guys.
Old Jan 3, 2014 | 09:00 AM
Evo82's Avatar
are they good? expensive? you have any experience with them?
Old Jan 3, 2014 | 09:44 AM
Nickolai's Avatar
I would maybe just take it easy on the boost until you get a solution to your tuning problem. Like others have said, its probably fine and the MAF should be able to adjust to the increased flow, but better safe than sorry with a car you recently purchased. If there were no tuners in my area, I would just get a Cobb AP then track down a reliable e-tuner.
One thing to add, why go with a DP next? From everything I've read here that isn't completely needed until you upgrade turbo or at least until you go further with bolt-ons. Not sure what your plans are for the future but TP or HFC might be a better starting point for the exhaust system.
Old Jan 3, 2014 | 02:07 PM
Evo82's Avatar
thanks Nickolai... i will install the ETS and if anything i can always go back to stock, and not really sure for the DP, forsome reason thought that i will need for the tune in the future. noob...still learning but for now i want to get much as i can from the stock turbo....is Cobb tuner any good?
Old Jan 4, 2014 | 06:01 AM
Fotown's Avatar
I'd say they range on the higher side of the price scale, but they are very good, in both installations, professionalism and recommendations on where to go with a build
Old Jan 4, 2014 | 06:31 AM
hamburger_train's Avatar
Don't waste your time with a Cobb AP. If you want to do more than their free maps support, mods wise, then you'll be spending 500 for some digital gauges, because you'll have to get a protune anyway.
Trust me, I just went through this.
Install all of your bolt ons then get a tune, otherwise you'll be paying for a new tune for every mod?? And why for like a 10 hp gain? Do it it all at once so you pay once.
Last edited by Iowa999; Jan 4, 2014 at 10:08 AM. Reason: No advertizing in tech threads
Old Jan 4, 2014 | 06:01 PM
sw2oboi's Avatar
You will be fine with out a tune but just know that you will be running lean.
Old Jan 4, 2014 | 07:10 PM
Iowa999's Avatar
If the second half of the above is true, then the first half is not. One of the most dangerous things to do with a forced-induction engine is to run lean.
Old Jan 5, 2014 | 02:13 PM
sw2oboi's Avatar
oops, i should reword that. "You will be fine if you lay off the boost."
Tsane
Cobb AccessPORT
Oct 28, 2015 01:08 PM
Tsane
May 29, 2015 04:29 PM
Brandon982
Cobb AccessPORT
Feb 10, 2014 11:09 AM
evo jason
Jan 11, 2012 09:01 PM
Brsox10288
37
Nov 22, 2009 11:37 AM
