Sponsored by:
Sponsored by: CARiD
First time doing this input needed.
Old Jul 4, 2014 | 08:38 AM
Jerm6908's Avatar
Originally Posted by Iowa999
Too bad there isn't a set of pictures showing what goes where in a sticky-thread at the top of this sub-forum.
Agree....So what was the fill plug on the passenger side that said ATF for? ...An still confused why both front a rear fill holes said "GEAR OIL" for the drivers side.
Old Jul 4, 2014 | 09:45 AM
Iowa999's Avatar
Sarcasm phail.
https://www.evolutionm.net/forums/ev...ssues-etc.html - scroll down to last post
Old Jul 4, 2014 | 09:54 AM
Jerm6908's Avatar
Yes this is what i did.
I'm take a pic of where yous are saying add ATF an tell me if it's where you add ATF cause i added gear oil where it said gear oil..i added ATF where it said ATF.
Old Jul 4, 2014 | 10:15 AM
Jerm6908's Avatar
Ok 2 fill holes driver side both say gear oil I put LSD 90 in front one an what yous are saying is the back one uses ATF even though it says gear oil? I just wanna get it right that's all.
Now that I look at the picture it looks like I did it right ATF is on otherwise of that middle plate gear oil other side...What I was asking if those 2 same fill holes for the gear oil had the same purpose just choose if you wanted to use front hole or back hole.
Old Jul 4, 2014 | 10:45 AM
Iowa999's Avatar
You only use the ports shown in the picture I attached. I don't know what any of the other ports connect to. My general approach is to follow the FSM as closely as possible.
Old Jul 4, 2014 | 10:58 AM
Jerm6908's Avatar
That's what I did exactly what that pic shows I guess me wondering if them 2 gear oil fill holes are the same for the same purpose will haft to wait even though I read it was on another form I just wanted to make sure even though I still used the front one...... 1.I did it correctly an 2. No do not add ATF to that rear gear oil plug I think them 2 guys we're confused.
Old Jul 4, 2014 | 11:08 AM
Iowa999's Avatar
There's a good chance that the other one is also a fill port, maybe for cars with different directions of easy access, but I try to avoid making assumptions of that sort, on the off chance that the other one, which might look like a fill port, is actually a bolt that holds something inside. It would be, um, sub-optimal if you had to tear the diff casing apart because you pulled the wrong bolt.
Old Jul 4, 2014 | 11:30 AM
Jerm6908's Avatar
True that man.... And like my first post says this is confusing..Even though I got it right.. also glad I didn't go an add ATFIII in there like some said... I guess not many noticed or asked about it idk.
Grilla
Mitsubishi TC-SST Discussion
37
Apr 8, 2021 11:00 PM
RATEDX
Mar 15, 2016 05:42 PM
kjcs9
Dec 23, 2015 07:41 AM
BEKevo
11
May 6, 2012 07:29 PM
orangeorphan
Jun 4, 2009 07:33 PM
