Sponsored by:
Sponsored by: CARiD
Evolution X helpful FAQ, TSBs, known issues, etc.
Old Apr 23, 2009 | 07:18 AM
Noize's Avatar
EvoM Administrator
Generalized Evo X info
-https://www.evolutionm.net/forums/ev...formation.html
-Maintenance schedule, TSB, fluid specs, etc
-How does the Evo X compare to the Evo VIII and IX?
-What will the 2010 Evo have compared to the 2008?
-TPMS FAQ borrowed from the Lancer section
-https://www.evolutionm.net/forums/ev...en-gsr-mr.html
-https://www.evolutionm.net/forums/ev...ing-chart.html
Engine/turbo/driveline concerns
-Exhaust: black smoke
-Transmission shifting is notchy/grinding
-FPR hose popping off - lean idle
-Factory transfer case fluid over-filled
-https://www.evolutionm.net/forums/ev...-failures.html
-What does ASC do? ASC problems/ ASC light is on
-Evo X and RA SST Forum
Appearance/cosmetic concerns
-Paint is chipping in spots
-Seat fabric coming apart (Why do I see the staples in the seat?)
ECU concerns
-Limp mode
-Mitsubishi factory reflashes, hesitation, and stalling
Suspension/Brake concerns
- https://www.evolutionm.net/forums/ev...ct-thread.html
- https://www.evolutionm.net/forums/ev...art-evo-x.html
Gold stars and kudos to all of you that helped Smike and I with the leg work and ideas we used to make this thread: Spy007, KGHtheII, gunzo, goofygrin, Blacksheepdj, dek0026, atombomb33, mad VIII, jwoods986, ►EvolutionX◄, TTP Engineering, and RussellM.
Thanks a ton, guys!
We will add more as we are able.
Old Apr 28, 2009 | 01:19 PM
Noize's Avatar
EvoM Administrator
Streamlining sticks, added TSB link to clear clutter at top in X General.
Old Jun 18, 2013 | 07:38 PM
Iowa999's Avatar
Here are three useful screen-shots from the FSM for changing fluids. Even if you have someone else do the work, handing them copies may save your car.
Attached Thumbnails Evolution X helpful FAQ, TSBs, known issues, etc.-tranny-fluid.jpg   Evolution X helpful FAQ, TSBs, known issues, etc.-transfer-fluid.jpg   Evolution X helpful FAQ, TSBs, known issues, etc.-rear-fluids.jpg
SoloSpeed101
May 23, 2023 10:34 PM
joel794613
Apr 14, 2017 02:51 PM
down_under
Jan 23, 2014 11:22 AM
TrailBrake
Toronto Lancer Club
83
Jun 7, 2013 06:32 AM
RussellM
MitsubishiParts.net - WA
16
Sep 1, 2011 10:12 AM
