Sponsored by:
Sponsored by: CARiD
AMS Downpipe removal help
Old Oct 28, 2019 | 05:04 PM
Alh925's Avatar
Angry AMS Downpipe removal help
I am in the process or removing the turbo and downpipe, i already have everything disconnected except the one bolt on the back side of the downpipe that faces toward the passenger wheel. All other bolts facing toward the turbo are out but i am having issues getting anything on the one bolt facing the opposite direction. Looking for suggestions on what youve used to do this.
Old Oct 28, 2019 | 06:58 PM
Napalm_Enema's Avatar
PBBlaster - let it soak in - if that doesn't work you may need to apply heat. You may want to put the other opposing bolts on as you break that one loose to give it some leverage. Downpipes are never fun.... Good luck!
Old Oct 28, 2019 | 07:04 PM
Alh925's Avatar
I have soaked all the other bolts with on blaster and had to heat them to get them off. That’s not the issue with this last bolt, just getting a tool on it with any type of leverage is.
Old Oct 28, 2019 | 07:08 PM
I've seen it done with crazy cobbled together ratchet extenders - it's not fun. Good luck man, what you don't want to do is snap it off, so keep soaking and working at it.
Old Oct 29, 2019 | 06:56 AM
llllBULLSEYE's Avatar
I know horrible pic
this is what you need 2ft extension and swivel at end
and some luck of course.
Old Oct 29, 2019 | 11:17 AM
LetsGetThisDone's Avatar
Go through the passenger wheel well with socket/extensions/ratchet to get to it
Old Oct 29, 2019 | 04:00 PM
Originally Posted by llllBULLSEYE
I know horrible pic
Hahahaha that's the picture I was remembering seeing when I posted that - classic
Moose4B11
Oct 2, 2016 10:10 AM
Tractionlimit
Aug 4, 2016 03:25 PM
ahendrickson
Evo X How Tos / Installations
Apr 16, 2013 05:58 AM
fuzzychi
Jun 20, 2010 08:40 PM
Go2fast
Lancer Aftermarket Forced Induction Tech
Jan 26, 2006 03:13 PM
