Sponsored by:
Sponsored by: CARiD
Larger heatshield for AMS intake
Old Feb 26, 2020 | 09:41 AM
Third in Queue's Avatar
Does anyone sell a larger heatshield that fits an AMS intake? After getting tuned with one, I kept getting a lean code. Tuner deduced the high temps (90F+) along with the small heatshield and placement was drawing in too much hot air. They said since it was a common issue with the AMS setup, they were unwilling to check it out until cooler weather hit to narrow down the issue. I guess they were right, because once temps dropped below low 80's I didn't trigger the code again. Never had this issue with the ETS intake/shield, but I had a different tune too. Fuel pump is fine, no exhaust leaks.
Will something like this fit/help? https://www.maperformance.com/produc...stm-evox-inshd
TIA. Apologies if this is a dumb question, not that well versed on this particular issue.
Old Feb 26, 2020 | 12:52 PM
splattj's Avatar
Honestly, the tuner should be able to compensate for IAT variations. Either way, that heatshield you linked should help lower your IATs which isn't a bad thing by any means and something you should get.
Old Feb 26, 2020 | 12:58 PM
spam2012's Avatar
does this fit Buschur intake? I bought Driven Fab Heat Shielf for $60 and it did not fit the Buschur intake. https://www.driven-fabrication.com/c...er-heat-shield
Old Feb 26, 2020 | 01:34 PM
llllBULLSEYE's Avatar
I dont think The heatshield is the Problem as the AMS is a really good one. I have the STM one and it does not cover too well,
but then again the only purpose of the heat shield on the Evo x is to prevent the hot air from the fan once it turns on.
Then again for $40 bucks its worth a shot you can sell your AMS shield for a lot more then that.
Keedo
Aug 26, 2014 01:01 PM
Steven_Trujillo
Jan 11, 2014 07:09 PM
KeDoSH
Jun 27, 2011 03:03 AM
Kanweezy
May 24, 2010 07:21 AM
pure_butane
Jan 27, 2010 08:41 AM
