Sponsored by:
Sponsored by: CARiD
Evo X MR - 2015 - Mod Recommendations
Old Jun 1, 2020 | 11:18 PM
Dreamvo's Avatar
Recently purchased an Evo X MR a couple months ago with 35k miles completely stock. After dailying it for the months I've had it, I looked into what I'm gonna need to start pushing the car to be faster and most people are saying I'm going to need to do a transmission upgrade if I wanna start reaching higher numbers. Currently I am not in a position to start spending a ton of money on big boy upgrades like that but I am looking to see if theres anything in the 1-3k department on making the car slightly more faster/louder/overall more fun. If I could get some advice that would be great! Thanks in advance!
Old Jun 2, 2020 | 06:08 AM
Jacblack's Avatar
The biggest thing with SST cars is having the budget to knock out a lot of the preventive things on the car, such as reinforcing the transmission. Now in your budget you could do a few bolt ons, but it's important to find a tuner that can actually tune for the SST.
Old Jun 2, 2020 | 08:07 AM
RazorLab's Avatar
Proper Tune + 3-port boost solenoid + Catback will make it feel like a completely different car, in a really good way. Right in your budget and safe for the transmission.
Old Jun 2, 2020 | 11:57 AM
LetsGetThisDone's Avatar
Dodson heated sump for the trans, intake, test pipe or high flow cat, catback exhaust, 3 port boost controller, tune. That will get you about 320-330whp and the same for torque and really bring the car to life.
Old Jun 6, 2020 | 03:14 PM
hixlancer's Avatar
Veteran: Army
1-3k range you’re going to be looking at basic bolt ons and a tune. To max your budget I would say 3port BCS, 3” exhaust from the turbo back and a tune. If you can break the budget a bit I would suggest fuel pump (walbro 450), flex fuel kit and injectors (~1300cc), possibly a fpr. It would save you money in the end to have this setup if e85 is available near you so you won’t have to adjust your tune later and leaves room for more when you get bored (which you may) and want to upgrade your turbo.
Old Jun 8, 2020 | 09:59 AM
Down pipe isn't needed for a stock turbo. That $600 plus install labor is better used elsewhere, like an intercooler.
Old Jun 8, 2020 | 11:13 AM
RazorLab's Avatar
I wouldn't even touch the dp and not even the catback unless you want more sound. I've run 450whp through the OEM Evo X exhaust with just a testpipe.
Old Jun 11, 2020 | 02:00 AM
DRAGHICI's Avatar
You don’t need a new trans!
My MR X has over 170000 miles on original clutches and complete Bolton’s since 56000 miles.
I’m pushing around 330-350whp :-)
603Guy
Jul 16, 2019 06:35 PM
Damian Doan
Australian Forum
Mar 16, 2017 08:03 PM
Sev
Mar 27, 2011 11:15 PM
A03
Mar 8, 2009 12:00 AM
tmitchell
Mar 24, 2005 09:17 PM
