PT 5558 gen 2 and 6266 gen 2
Can anyone here tell me on stock block on 91 fuel and e85 at what rpm these turbos hit full boost (20psi) at? Also if adding gsc s2 cams and springs retainers, what difference does it make
Approx 4200 rpm for 20psi, 4700 for 29psi.
5858 Gen 1, add about 150rpm on both.
Either, 5858 seems to have a little bit more top end. I used the 5858 a lot on track and it can make enough power, even at only 25psi, with a built engine to hang with the big dogs. Vipers, GT3s, ZL1s, etc.
ty sir anything similar to the 5858 on Garett turbo by any chance? Your feedback is well appreciated
ty very much sir you’ve been very helpful I’m currently running the 3071R gen 2 at the moment now I don’t know if a 5858 is gonna be a big difference as far as power is concern. I will definitely look into all the turbos you’ve recommended.
hi
turkish citizenship
On a fully constructed 2.0, which turbo would you recommend for track use and canyon runs?
turkish citizenship
nathantk94
Nov 26, 2018 01:21 PM
