Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Looking how to remove AC cover panel?
Old Apr 13, 2008 | 10:34 AM
Spazpilot's Avatar
Like it says. Seeing if anyone one has the part of the manual to remove the center part that houses the HVAC controls. Thanks in advance CJ
Old Apr 13, 2008 | 03:08 PM
Talon_66's Avatar
Pull on it
Old Apr 13, 2008 | 03:10 PM
EvoDan2004's Avatar
pull the knobs off. take out the 2 screws that are there and then pull the panel off.
Old Apr 13, 2008 | 03:57 PM
Spazpilot's Avatar
I was kind of affraid to pull the knobs. It seemed like it was going to break apart between the outer and inner. Thanks I will give it a try
Old Apr 14, 2008 | 10:09 AM
kimletrim's Avatar
Registered User
This is the Evo X Forum. What you are describing is removal of the AC panel for the 8 and 9. I think the 10 is a bit more involved.
Old Apr 14, 2008 | 12:08 PM
DirectorSe7en's Avatar
Originally Posted by Talon_66
Pull on it
LOOOOL!
Old Apr 14, 2008 | 08:17 PM
Spazpilot's Avatar
I have a X now. Yep after reading it the second time pulling it will not work. The knobs also don't come off. I went ahead and order a service manual and will post up pics for anyone interested. I am planning on installing a boost gauge just below the A/C pannel above the ashtray and lighter in the little cubby type space.
Old Apr 15, 2008 | 10:10 AM
kimletrim's Avatar
Registered User
Do not pull on it! Basically, you have to remove the long plastic centerpiece (really fake CF looking piece), and then remove the radio panel. You have to remove these to access the two screws which hold the A/C panel in place. Once the screws are removed, you can gently pull the panel off.
Old Apr 15, 2008 | 11:24 AM
RKT SHP's Avatar
I thought for sure somebody would have helped you out so i didnt post. i just put in a rear view camera in my EVo and i had pretty much the whole dash apart because i dropped a screw and I was determined to find it. This thread helped me out as far as removing the ac cover panel
https://www.evolutionm.net/forums/sh...d.php?t=311198
Old Apr 16, 2008 | 12:33 AM
Spazpilot's Avatar
Thanks RKT SHP. that helps out a lot. I figured it had some screws hiding.
Old Dec 9, 2010 | 01:17 PM
MPACT's Avatar
Bump for this. Anyone had any luck removing the HVAC knobs on the X?
Old Dec 19, 2010 | 12:07 AM
stokEd's Avatar
Do you need service manual screenshots?
CaptainSquirts
Jun 1, 2017 05:53 AM
GsrJake
Apr 6, 2013 06:48 AM
EvoIXPilot
Feb 23, 2013 12:27 PM
ynotlim
Lancer How Tos / Installations
May 17, 2010 04:50 PM
chowetime
04-06 Lancer Ralliart How To Requests / Questions / Tips
Oct 20, 2006 08:39 PM
