Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HID conversion on GSR non-SSS
Old Jun 5, 2008 | 08:10 AM
ITALIANX333's Avatar
Has anyone done this conversion yet? I heard the X has a projector style housing, so regular HID bulbs will be twice as bright, is this true? And if it is, which HID conversion will work for non-sss GSR's?
Old Jun 5, 2008 | 11:59 AM
Taryon's Avatar
Non-SSS equipped GSR's use reflector housings, not projectors unfortunately.
Old Jun 5, 2008 | 03:16 PM
Mightygnu's Avatar
I have put HID's in my Base GSR. They look great, only thing you get with projectors is a really nice cut off..
Old Jun 6, 2008 | 05:20 AM
Did you just do the bulbs, or a full conversion kit? Pics?
Old Jun 6, 2008 | 11:07 PM
Mightygnu's Avatar
Just some ballasts + 9006 Bulbs... Easy install.
One problem, you have to have the headlights on all the time, due to the DRL's. If you don't have the lights on, they will flicker and then go out.
Old Jun 7, 2008 | 09:54 AM
Dosagex's Avatar
Mightygnu, sometimes when you start your car do only one of your bulbs turn on?
I have this issue sometimes. causes me to turn them off then back on.
Old Jun 7, 2008 | 10:33 AM
Mightygnu's Avatar
It did that when I first installed them, just check the connections from the ballasts, that solved it.
Old Jun 7, 2008 | 11:34 AM
jimm's Avatar
How much did this cost you? Where did you get the bulbs and ballasts?
Old Jun 8, 2008 | 08:16 PM
what happens if you pull fuse #13 and disarm the DRL?
Old Jun 14, 2008 | 08:56 PM
Mightygnu's Avatar
This does not kill the DRL's
Old Jun 18, 2008 | 12:54 PM
jimm's Avatar
Where did you get your HIDs? how much?
Old Jun 23, 2008 | 05:14 AM
spooled_u's Avatar
You can just get them on ebay. They're like $110 shipped for bulbs and ballasts. I'm not sure what bulbs the X uses, but the Civic Si's use 9006 for low beams. $110 shipped, it's just a plug n play kit for all cars.
Old Jun 23, 2008 | 10:39 AM
Mightygnu's Avatar
It is a 9006 Bulb
Old Jun 24, 2008 | 02:39 PM
StevenStarke's Avatar
you can use the SSS headlights, u just need to get an HID kit that does NOT have a rebased bulb. You need a D2S bulb with your HID kit
Old Jul 11, 2008 | 12:09 AM
nbpal4000's Avatar
how much is the sss headlights? anybody?
