Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Where to obtain switched/accy 12V supply from
Old Jul 16, 2008 | 01:14 PM
Dyno4mance's Avatar
Originally Posted by JoeyM3
you should have saved yourself a headache by buying the add-a-fuse
+1
Thats what I did on my VIII and my X. Use the owners manual to decode the pretty pictures on the interior fuse pannel cover (which btw was installed upside down on my car and several others, the legend that is) and find a switched source.
I used the gauge fuse location and a mini add a circuit for my innovate lma-3, lc-1, and xd-16's.
Old May 12, 2011 | 06:13 AM
Summit1's Avatar
Hardwiring to two switched fuses
I hardwired both my GPS (Garmin) and Passport radar in my Evo X interior fuse panel. i used the "add-a-fuse" which allows you to piggyback an existing mini fuse with a second fused connection. The GPS and RD only require 1 or 2 amp fuses, so they would not seem to be much incremental load.
Here's the issue I ran into -- which fuses on the interior fuse panel are actually switched (i.e. turn on and off when the ignition turns on and off)?
I thought for sure the Radio fuse was switched -- nope. Even though the radio goes on and off when the ignition turns on or off, the fuse (#4 i think) is hot all the time.
Two fuses which are switched: cigarette lighter/accessory (15A) and exterior electric rear mirrors (10A). The second accessory fuse is hot all the time, as are most other fuses.
Old May 12, 2011 | 07:31 AM
armysoldier1073's Avatar
the easiest place to hard wire a radar detector is the cigarett lighter. i put the remote mute button in the ghost spot next to the ASC button.. i ran the power and ground under dash and used the blue wire splice to the power and ground of the lighter wiring..
Old May 26, 2011 | 01:12 AM
jdm sam's Avatar
The fuse box is the easiest place. A 12v switched supply runs to the junction box in every car for accessories.
Rallyman
48
Dec 18, 2025 06:45 PM
Prolifik
Aug 27, 2013 03:18 AM
aZnLaNcEr
Dec 27, 2005 12:52 PM
Evo_doer
Apr 21, 2004 09:38 AM
Barse
Lancer Troubleshooting
11
Aug 17, 2002 12:23 PM
