Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
how to change diff and tranny fluid
Old Sep 28, 2008 | 05:15 PM
BKevoX's Avatar
hey just wanted to know how to change the tranny and diff fluids today...what do i need and how to do it the easiest way... thanks for the help
Old Sep 29, 2008 | 06:26 AM
TTP Engineering's Avatar
Pull the drain plugs and refill until it starts to stream out of the fill hole, indicating that its full.
Old Sep 29, 2008 | 06:31 AM
vvhiteix's Avatar
probably a little pump as well to make filling them back up a little easier.
Old Oct 23, 2008 | 07:45 PM
slowfera's Avatar
Be Careful
I would be careful with the diff. I have changed my transmission fluid and it was a snap but the diff is a little bit different on the x. I will post what the service manual says to do. And you can take it from there. Sorry but the file is too big and it want let me post it. Needles to say in the service manual there is a bleeding step for the new diff in the evo x. Don’t want you to kill your car or your diff. You know how service techs are your fault no warranty. Okay now I got it but it’s just a little bit so you can see for yourself.
File Type: pdf
Old Oct 23, 2008 | 08:54 PM
I believe they are referring to ACD fluid in that manual page, not the transfercase fluid.
None of that appears to apply.
Old Nov 4, 2008 | 09:18 AM
slowfera's Avatar
Change Diff and Tranny fluid
If you look at the top of the page is does say that is for the diff and not the ACD unit. It works the same for the front and rear diff. That is what the service manual says anyway. It would help if I could post all of it.
Old Dec 26, 2008 | 12:41 PM
GNR's Avatar
GNR
The ACD unit calls for mitsubishi transmission fluid Sp3 (non-synthetic). Can I use AMSOIL AUTOMATIC TRANNY OIL?
rcheung
Aug 3, 2010 09:02 AM
got_em
26
Mar 18, 2010 09:50 PM
CanadianEvo
13
Aug 13, 2008 08:30 PM
S1monLM
Jun 16, 2008 05:36 PM
Kierkegaard
Apr 10, 2007 07:52 PM
