Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Spring Install - Tein S.Tech
Old Mar 18, 2013 | 08:21 AM
  #91
ALBOOGY's Avatar
Great how to !
Old Mar 23, 2013 | 07:04 PM
  #92
dasmikechen's Avatar
Its really not bad if you are willing to pick up a set of spring compressors and have an impact wrench (battery, electric, or compressor should work). Definitely worth doing all around for handling and look.
Old May 6, 2013 | 02:55 PM
  #93
evo_2012gsr's Avatar
I did this install with some h&r springs this past weekend. The job is easier with two people but can be done by yourself. The biggest pain is if the front springs top bolt doesnt loosen and just spins the piston. I found putting a strap wrench on the piston itself worked then I was able to get that sucker off. Other than that it was a piece of cake and saved me $$$.
Old May 24, 2013 | 12:55 AM
  #94
Evo4Emperor's Avatar
my question is for the front top nut.
after installing the entire thing back onto the car and i tighten up the top 3 nuts on the strut bar, what do i do with the top nut?
if i try tightening it the springs just spins and ends up messing with the rubber washer and i have to re do it all over again.
do i just wait until the car is back on the ground and then tighten the top nut?
thanks guys!
Old May 24, 2013 | 04:05 AM
  #95
jracer's Avatar
how bad was the alignment after the install ?
Old May 24, 2013 | 04:21 AM
  #96
ZLAYER's Avatar
thanks guys!
I had the same problem. I was all fired up to torque everything down with my new torque wrench, bout that sob just kept spinning. And messing up the alignment of everything. So plan B was to hold everything stationary while my buddy used an impact gun to snug everything up.
Old Jun 24, 2013 | 03:30 PM
  #97
RipTideRA's Avatar
Great write up! My buddy and I had mine lowered in an hour flat, seriously... its really simple, the easiest car I have ever lowered and I have done a few!
2011, Tein Springs
Old May 29, 2014 | 04:28 PM
  #98
LiquidGraphite's Avatar
Great write up. Just finished my Eibach Pros with this! Everything is pretty straight forward and I must say, an impact helped significantly
Old Jun 4, 2014 | 08:22 AM
  #99
Astar23's Avatar
Great write up! Really helped me and a friend install his.👍
Lightsaber
Apr 4, 2018 10:02 AM
sdfontanini
Apr 15, 2014 09:17 AM
dimi108
Mar 18, 2014 02:45 PM
UT_EvoX
Evo X Dyno Results
10
Dec 23, 2011 11:12 AM
UT_EvoX
Nov 22, 2011 10:04 AM
