Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
HOW TO: Debadge your trunk.
Old May 5, 2013 | 07:53 AM
  #121
Omg AWD's Avatar
Just did mine yesterday. Took everything off but the evolution badge. Looks awesome. Thanks for the write up.
Old May 18, 2013 | 07:45 AM
  #122
Bmore_EvoX's Avatar
Did it this morning
Attached Thumbnails HOW TO: Debadge your trunk.-debadge-photo.jpg
Old Mar 10, 2014 | 01:44 PM
  #123
JayK's Avatar
I am stocking my car back. Now i just need to find where i put those badges and reapply them. Anyone know of a good adhesive to do that with?
Old Mar 10, 2014 | 04:03 PM
  #124
Thomar's Avatar
3m double sided tape
Old Mar 10, 2014 | 04:19 PM
  #125
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Eeehhh, I would just get OEM badging IMO.
3M double sided tape is going to stick the badge out much farther than the OEM adhesive, which is going to look pretty ghetto.
Old Mar 11, 2014 | 12:33 AM
  #126
flawlessninja's Avatar
did this tonight with fishing line, a heat gun, goo gone, water and some clean microfiber cloths... All that's left is the Evolution badge.
I didn't have very good lighting in the garage so hopefully it turned out ok... The adhesive was a ***** to get off... even after using the heat gun for a little while between badges it took a few rounds of goo gone to come off. I'm hoping I didn't scratch the clear coat too badly while I was doing this...
The car will be getting detailed pretty soon though, so that should help smooth it out if anything is wrong.
Thanks for the writeup. Pretty straight-forward process.
Old Mar 11, 2014 | 09:47 AM
  #127
Sev's Avatar
Sev
+1
It's worth spending a little more $, it looks better.
Old Mar 11, 2014 | 10:04 AM
  #128
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I've never had a problem. Do you let the goo gone soak for a bit to break down the adhesive first? That's the trick... patience.
Old Mar 15, 2014 | 09:37 AM
  #129
evostanman's Avatar
Honestly I preffer the badges on my X
It's just me though.
Old Apr 4, 2014 | 12:15 PM
  #130
TEXAS05EVO's Avatar
Works great i used a Blower Dryer also only on the end of lancer due to for some reason it was way stickier right at the end and the floss broke 10 times i just held it far away 12" and moved it side to side being careful not to leave it in one spot
Old Apr 11, 2014 | 11:35 AM
  #131
ToMinLA's Avatar
100 lb. Shark leader even better (lol)
Originally Posted by tkromer
I did the same, should have pointed that out. 10 lb test mono.
Old Apr 24, 2014 | 11:18 PM
  #132
Knorm's Avatar
Great write up
Old Apr 26, 2014 | 08:26 AM
  #133
mclaren's Avatar
I bought my x used and the person before me de-badged the entire trunk. When I bought the car I asked her how she did it because the are some marks in the clear coat from scraping them off. She told me that she used a credit card and goo gone. It just a bunch of rub marks in all sorts of directions. Nothing looks very deep in the clear coat though. The diamond is the worse of any of the trees areas on the trunk. What is the best way to clean this up at home without going to a detail shop. I have washed the area many times to see if some is just residue left over, should I get a clay bar? Polish? Wax? I'm new at detail stuff. Cheers.
Old May 5, 2014 | 03:12 PM
  #134
ikt's Avatar
ikt
3M 08008 adhesive. Walmart/Autozone/ORLY's sells it
put emblem face down on masking tape w/sticky side up
apply 3M 08008 to back of emblem. Use less than you think you need. Wait 15 seconds.
pick up tape w/emblem
stick emblem on car, press tape against surface to hold it. Wait a few hours, peel tape off, done
Old May 11, 2014 | 08:09 AM
  #135
fallenangel9673's Avatar
So thats how its done!!!
