Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Servicing Brakes
Old Jan 15, 2012 | 02:22 PM
The Kankler's Avatar
Servicing Brakes
I'm kind of new into the whole Evo scene, so please be easy. I keep getting a warning light for my brakes and I was wondering if there is a way that I could service the brake system myself. It would be awesome if pics were included. Thanks!
Old Jan 15, 2012 | 04:24 PM
Midnightcrx's Avatar
I would imagine that there is a write up on how to service your brakes. I know there is a video on YouTube that covers it. I would use the search function and I would also hit up google/Bing/Whatever. These are good tools to find what you need.
I have to replace my brake lines because the douche that owned my X before me didnt secure the lines away from the wheels. I don"t want to screw it up but I have faith that I can search and find the info i need somewhere on the internet. Congrats on getting an Evo!
Old Jan 23, 2012 | 10:49 AM
mbnworld's Avatar
the warning light is on the brake master cylinder for fluid level and for parking brake... what light do you have coming on.
Old Jan 25, 2012 | 06:30 PM
When I'm accelerating or cornering hard, my display shows the parking brake symbol and says "CHECK".
Old Jan 26, 2012 | 04:21 AM
mbnworld's Avatar
Ill check my tsb's today but i think there is an flash for that for that.
Old Jan 26, 2012 | 08:02 AM
Get Rad's Avatar
I do know that if you have to replace your pads you will throw a cell. Grab a set of calipers and measure the thickness of your pads. Most likely the front is worn down and need to be replaced.
Old Jan 26, 2012 | 09:39 AM
black95tt's Avatar
Check your fluid level. Mine was doing that as well and one of the bleeders was seeping (don't know how as I've never touched them). Tightened the bleeder, added fluid, and I've not had a problem since.
Old Jan 26, 2012 | 08:29 PM
Subi.convert's Avatar
There is no way this is correct. I would check your fluid level.
Old Jan 27, 2012 | 03:05 PM
Where and how can I check my fluid? If it is low, is that something I can service myself?
Old Jan 27, 2012 | 03:21 PM
Evolution Z's Avatar
all you gotta do is check the reservoir... if low, simply add with dot 3, 4, or 5... i forgot what we (us evo owners) require.
if it persists, it may be a leak somewhere (ie a line, hose, mc, ets...)
Old Jan 28, 2012 | 06:23 AM
ravenjam's Avatar
Unless you have a leak, which I doubt, I would not add fluid. If your fluid level is low it means your pads are low, replace them. If you add fluid, when you go to change your pads you will end up having to remove the excess fluid, unless you plan to bleed the system.
Old Jan 29, 2012 | 05:41 AM
mbnworld's Avatar
I agree, check pads before adding fluid. I use the fluid level to know when pads are low.
Evodetailer123
Apr 14, 2015 02:37 PM
jram
Apr 3, 2015 06:54 AM
chris4b11t
Mar 31, 2015 01:39 PM
jameswwt
Jul 16, 2014 04:09 AM
StancedEvoX23
47
Sep 7, 2013 06:49 PM
