Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
20mm Spacers & Handling
Old Sep 11, 2011 | 07:48 PM
Type17's Avatar
I wanna put 20mm spacers on my X to make it look a bit better. Will it mess with the handling?
Old Sep 11, 2011 | 10:36 PM
Freebs's Avatar
It didn't mess with mine at all. I didn't notice any benefit other than looks either.
Old Sep 12, 2011 | 02:14 PM
Iowa999's Avatar
Does "mess with" include help? If so, then the answer is yes.
Old Sep 12, 2011 | 05:26 PM
jimm's Avatar
I thought the wider track was noticeable and better.
Old Sep 12, 2011 | 05:58 PM
chu's Avatar
chu
Depends on the experience of a driver. Not many people will notice small changes, especially with the minor change in track.
Old Sep 12, 2011 | 06:07 PM
guswaym's Avatar
spacers do stress the axle more then a lower offset wheel but 20mm should be fine..
Old Sep 12, 2011 | 06:14 PM
jimm's Avatar
I have never understood how this can be true. A 20mm spacer has the same distance from the hub as a -18 wheel(in the case of an Evo x) and should have the same amount of leverage on the hub/axel.
Old Sep 12, 2011 | 07:03 PM
Iowa999's Avatar
If the wheel bearing were at the hub/wheel interface, then I'd agree and even suggest that moving towards a zero offset would reduce stress. But the wheel bearing is way inboard of the hub/wheel interface, such that moving much below the original offset will add stress on the bearing.
The key is knowing where the wheel bearing is relative to the hub/wheel interface.
ps. 38 minus 20 is +18, not -18
Old Sep 12, 2011 | 07:32 PM
WarmMilk's Avatar
^ he's asking why a spacer would stress the hub more than a wheel with the same resulting offset without a spacer, not overall offset. so a wheel with +18 offset or a wheel+spacer resulting in +18 offset
I agree with him that it doesn't make a difference as long as the "version 1" style spacers are used in the pic below. personally I'd never put the "version 2" spacers on my car
Old Sep 12, 2011 | 07:33 PM
The__J__Factor's Avatar
They will be sweet, the HKS Hipermax time attack evo runs something like 30mm + spacers without a problem. Lots of other track cars also run spacers without a problem.
High HP + hard track work should be enough testing/proof for people to realize spacers are fine to use.
Old Sep 12, 2011 | 07:42 PM
bmxking45's Avatar
SpaceRS are something that I am very interested in myself! Any recommendations as to which ones I should go for on my X?
Old Sep 12, 2011 | 08:58 PM
Iowa999's Avatar
Oh. Well, in that case, the answer is that it doesn't. The only differences between a +38 wheel with a 20mm spacer and a +18 wheel are, all else being equal, the +38 with spacer weighs more but has more caliper clearance.
Old Sep 13, 2011 | 06:26 AM
chu's Avatar
chu
Touge Factory sells the Ichiba brand, which are hubcentric. Call them, ask for Mike, and tell them I referred you...use my SN!
Luckystryke
For Sale - Wheels / Tires
Aug 8, 2016 06:34 AM
HaterMagnet
11
May 24, 2016 01:17 PM
Type17
16
Sep 15, 2011 09:21 AM
Mishi9
21
Nov 21, 2010 03:59 PM
mifesto
10
Sep 20, 2004 05:57 AM
