need info big question
Old Dec 28, 2006 | 05:40 PM
bigric09's Avatar
i just thought about this as well.... how old are you ? you have to be close to 17 and had mommy buy the car for you to not give 2 ***** about it and let some morons take it out for a spin
Old Dec 28, 2006 | 07:41 PM
bone's Avatar
loud CLUNK
Originally Posted by ShamelessCookie
Shifting as fast as you can from 1 to 2 and 2 to 3 often causes a loud CLUNK from the rear differential... this is normal, but it is not necessarily the best thing for the drivetrain.
You're putting a lot of stress on the rear diff when you shift that fast, and while it may be able to take it for a while, you'll eventually break something.
Do yourself a favor and keep it under 4500rpm until you hit 600 miles, then keep it under 5500rpm until you hit 1000 miles.
But by FAR the most IMPORTANT thing when breaking in a turbocharged car is to 1] Let it warm up before driving (at least until temp needle is above minimum) and 2] Do NOT hit boost or exceed 3500rpm until the temp gauge is at norm. If you hit boost and the turbo is still cold, you will regret it.
Now, conversely, you should ALWAYS let the car idle for at least 1 full minute before you shut it off... when I broke mine in, I would wait a full 2 minutes after every trip, even short ones, to make sure the oil in the turbo reached a safe temp.
i get that rear diff clunk also when i shift fast. the base IX that i test rode did the same thing. so how are you suppose to shift to avoid that?? i've driven all types of manual shift cars, i've seen videos of drag racing EVO's, so are you suppose to ease the clutch out on a 2nd to 3rd shift??? i'd really like to know if i'm messing up my car or not. thanks.
bnoe
Defcon5Es
Oct 1, 2013 11:24 PM
TwistedEvo8
Apr 6, 2012 08:16 PM
mungro23
23
Jan 11, 2009 12:32 AM
HOSrt4
South Region
10
Aug 14, 2008 03:32 PM
Dorikun
Jul 27, 2007 09:40 PM
