When to upgrade fuel injectors
Old Jul 20, 2008 | 08:22 PM
hytek369's Avatar
With my upgrade list in my sig, do I need to upgrade my stock injectors?
At what HP level would I need to upgrade? If the amount of HP is not the way to determine, what is the convention?
Old Jul 22, 2008 | 08:43 PM
hytek369's Avatar
no one?
Old Jul 22, 2008 | 08:46 PM
mx4life85's Avatar
..Kinda wondering the same thing!
Old Jul 22, 2008 | 08:49 PM
JTB's Avatar
JTB
You don't need to upgrade unless you do a larger turbo or are planning to run E85.
Old Jul 22, 2008 | 08:52 PM
mx4life85's Avatar
Would you have to upgrade if you got a FPgreen?
Old Jul 22, 2008 | 08:55 PM
JTB's Avatar
JTB
I went to the 780s when I installed my green. You wont be able to tap the full potential of the turbo without a minor upgrade. If I had to do it again I would go larger still so that I could tune for E85.
Old Jul 22, 2008 | 09:05 PM
IEXCELR8's Avatar
IMO-When you get to a 85%-90% duty cycle on the stock ones.
Old Jul 22, 2008 | 09:09 PM
o-townFLA's Avatar
if your runnin on 91 octane a lot of tuners here in Cali recommend you upgrade when you get cams...
Old Jul 22, 2008 | 09:10 PM
YzBrad99's Avatar
Stock turbo=stock injectors.
Stock ECU can handle like 880 cc i think.
Old Jul 22, 2008 | 10:40 PM
nonschlont's Avatar
If you log your car, you can log (IDC) Injector Duty Cycle, and you can see where your injectors are @. I have been told that the Injectors go "static" @ around 110% IDC. So anything 100% or over, its time to upgrade!
If you dont log your car, (u should) but if you dont, w/ most of the bolt ons, you will need them. Im @ 97-98% IDC w/ my current set up, minus the intercooler (getting installed tomorrow) and once I re-tune for the new mods, I will need Injectors! mods in my sig.
Old Sep 10, 2008 | 04:22 PM
htsai14752's Avatar
I have a evo 8 with fp green/cams right now at 78% idc on 660cc. If I downgrade to a stock evo 9 turbo on a 8 with cams, would I be ok with stock injectors?
ChicagoEvo9
Feb 5, 2014 03:30 PM
bigmatt33
Aug 8, 2013 08:41 AM
SmurfZilla
E85 / Ethanol
Mar 10, 2011 02:39 PM
riceball777
Apr 10, 2009 04:43 PM
Calito_Evo
28
Mar 22, 2006 02:38 AM
