MBC spikes to 25psi and CEL is on now!
mine spikes at ~20.5 then tapers to 18....but daMn, 25? yeah, i think that you should've turned down the boost before actually driving it after the install. nEway, just do what AzBlackEvo8 said and disconnect the battery and reconnect it AFTER you turn down some boost...
yea i work at honda so they hooked it up to this machine and the code was P0234 which is what yall were talking about(overboost).
but man im pretty damn sure i got it all the way counter-clockwise as i can get it !
there is no way it should be boosting that much !
Originally Posted by tehforbes
Just got a shop to install my hallman boost controller with the in-cabin controller. After we left, I just crusied around for a while. Finally I got on it and it spikes up to like 25-26 and tapers down a little bit.
Then after a while my check engine light comes on ! WTF ?!
Car is stock except for 3" TBE.
Any info will be helpful. Thx
-Ryan
-Ryan
Originally Posted by AzBlackEvo8
It all depend what octane you're running, on a 91 octane, I wouldn't do it more than 21psi. Even if you do turn it up more than that, without a flash or tune, you'll more likely to hit boost cut.
Just disconnect the battery and hook it back up again, it'll go away. No need to take it to anywhere.
Originally Posted by wizzo 8
Im running 93 octane
If you turn down your boost and that doesn't work it might be a problem with the MBC. My forge surged to 25+ once. The ball got stuck. Hallman might be the same way. Open up your mbc and make sure the spring is seated correctly and that the ball is not stuck at the top.
novaspyder87
Apr 23, 2012 08:02 PM
