Road and Track MR short writeup with Pics!
Originally Posted by Jovani
Anyone else notice in the engine pic it looks like we're not getting the MR aluminum BOV but the regular plastic one.
Originally Posted by cmf
And how likely is it that Subaru would *reduce* the power of the STi for 2005? The 25 lbs added for 2005 aren't likely to make it "a good bit slower."
I'm glad to see the MR turn out such great numbers, buf the figures for the STi seem a bit odd. I was just hoping for an accurate comparison, and this sounds like at least one of the cars wasn't quite typical.
No surprise on MT picking the Evo. They love the car and would probably pick it even if it didn't win any of the performance specs just because the seats are so awesome.
Really, then you seriously don't know our staff. We're probably 50/50 between the two cars and we've gotten to experience both for the last year on our long-term fleet, so we've had plenty of seat time in each.
Please don't make general statements like this when you know none of us personally.
EVO_Neil , I'm just curious about the clutch of the Evo MR. Since you have driven and tested it, I would like to ask you some things that confuse me. Does the 5k rpm limiter placed on the clutch affect heel and toe technique when running on a race track? Correct me if I am wrong, but does it mean that because of the 5K rpm limiter, it is not possible to be running on 2nd gear at 6,500 rpm then shifting to 3rd gear?
If you are going to flash the ECU that will not mater The STi will run as well as the '04s. The 2-step rev limiter should not matter on the evo as well.
If you couldn't upshift from say 1st to 2nd past 5,000 rpm, people would mark Mitsubishi's neck so they know where to hit it with the axe. It would make driving an absolute nuisance. The car wouldn't of won the comparison tests because the 5k limiter would prevent them from wringing the car out and keeping it properly in its powerband. If you shift at 5K in the Evo, you're going to drop WAY out of the powerband. No way you'd be putting down anything resembling a fast lap.
The 5,000rpm second stage limiter is probably also tied to the speed of the car. Like... < 5 mph or something. Neil can surely clear this up.
Originally Posted by theblue
how did you like the gear ratios of the 6 speed... what were the upsides and downsides compared to the 5?
Dude...chill. A lot of the shoot-outs in your mag end up with the winner not being the fastest or most powerful car, but the one that is most enjoyable to drive. That's a good thing, IMO. That's all I meant...no need to get bent over it.
Originally Posted by arslanh
CAN ANYONE TELL ME IF THIS ONE COMING TO THE US HAS THE Super AYC ?
