Rev limit set to 7,000 reguardless?
Old Sep 25, 2004 | 02:13 PM
areet's Avatar
Well, I'm running the Stage 2 map from TurboXS for the 1.7 software. I have my rev limit set at 78 (7,800), but it hits the rev limiter at 7k for some reason. How do I fix this?
Old Sep 25, 2004 | 03:20 PM
Hot Feces's Avatar
How is that map working out for you?
Old Sep 25, 2004 | 03:21 PM
areet's Avatar
Pretty good, I need to hook up my EGT gauge and the tuner pro still. I love the launch control! The whole thing about it still pulling then hitting a brick wall at 7krpm kinda ruins it :/
Old Sep 25, 2004 | 07:27 PM
MalibuJack's Avatar
Do you know what your MAF reading is at 7000rpm? Did you set any of the other open loop parameters or the Launch control?
The reason I'm curious about the MAF reading is because you can set a maximum MAF value in the open loop control so the ECU doesnt get "upset" if you exceed what it expects to see... If you can capture your logs from the event it should be pretty easy to tell...
Old Sep 25, 2004 | 07:35 PM
areet's Avatar
I actually do have a log of it, but it's 11k big. I'll try to find just that part in the 6000-range. I was running the stageII map from turboxs. Launch control was enabled, and set at 5,500rpm.
Old Sep 26, 2004 | 09:03 AM
Spec C's Avatar
are you sure you have open loop on?
Old Sep 26, 2004 | 10:28 AM
MalibuJack's Avatar
Yeah good point, its possible its not enabled..
Old Sep 26, 2004 | 10:50 AM
boostfed's Avatar
how do you like the launch controll. I can't wait to get a piggyback and tune my car and have launch controll.
-Chad-
Old Sep 26, 2004 | 11:49 AM
Spec C's Avatar
-Chad-
Launch control is a pretty cool feature.. You "may" be able to get slightly lower 60's with out it but Lc is VERY consistant..
The beauty of LC IMO is Flat shifting.. Never letting your foot off the gas and staying in boost between shifts is BIG..
Oh and how dare you call the utec a piggy back
Old Sep 26, 2004 | 04:13 PM
areet's Avatar
I figured it out with the logs. I'm a moron. I rest the tip of my foot on the clutch RIGHT when i'm about to shift (like 1/2 second). Right at 6,900rpm it says "LCM" then decelerates on the logs. ROFL.
Old Sep 26, 2004 | 05:01 PM
justrick's Avatar
glad you found the problem i fdid the same thing a while back....also if you change your rev limit you have to reset the utec....
rick
Old Sep 26, 2004 | 05:46 PM
MalibuJack's Avatar
hahaha.. Ya know I just assumed that it wasn't launch control.. Its funny you mention it, I have my clutch switch adjustment so it takes more than just resting on the pedal to "Kick it in" so I never would have seen it.. LOL
Old Sep 26, 2004 | 06:08 PM
areet's Avatar
Haha. How do you adjust that switch? It kind of catches you offguard.
Old Sep 26, 2004 | 09:18 PM
MalibuJack's Avatar
Its got a threaded body, I think, you should be able to move it slightly.. I only moved it enough to not engage when my foot was resting on the clutch pedal (even though I don't drive like that) But now that I think about it.. I don't think I would have ever needed to adjust it if I didn't need to screw around with it at one time.
Old Sep 27, 2004 | 12:13 AM
areet's Avatar
I find it funny that launch control kicked in about 50rpm before redline everytime. if I could speed up my clutch depressing to that, it would be for some mean shifts (btw launch control at 5,500rpm sucks for flatfoot shifting).
03OZstocker
Lancer Engine Management / Tuning Forums
Mar 30, 2017 10:27 PM
blitzkreig
Jun 20, 2016 10:35 AM
danfalcas
Sep 30, 2015 08:25 PM
VRP
Oct 7, 2014 10:06 AM
bondango
Jun 9, 2008 01:35 AM
