Differences in ecu response to knock question
After ecu reads knock from the sensor it reacts with changes in fuel and timing.
What causes the differences between the following:
- The ecu reverts back to it's naturally tuned state (e.g., flash) immediatly after the WOT pull is completed. Or,
- When you have to reset the battery in order to run the currently tuned map? The ecu will continue to run retarded until "clrl alt deleted"
Bump
I'll make the question more understandable.
When the ecu pulls timing and adds fuel from knock does it
1. Go back to normal operation after the WOT pull is done?
2. After the ecu is reset from battery disconnection?
3. Both (depends)?
Why and how?
Thanks
3. Both (depends)?
Why and how?
Thanks
BTW It's the level of the knock sensor signal that is used.The sensor output is filtered so it's level represents the intensity of knock vibrations. The frequency of the filter is chosen to match the vibration response of the engine / block.
The ECU calculates retarded timing in time for the very next cylinder to fire.
Some vehicles use resonant sensors that don't need filtering, as they have a spring mass system that resonates at the appropriate frequency for the engine.
Originally Posted by siggo
The ECU ramps back the ignition timing over a matter of seconds, unless more knock is detected.
l8r)
hi.
besides reducing timing and increasing fuel, if knock is sensed, will the stock ecu also reduce boost (assuming no manual boost controller)?
just wondering, as it seems to me that by reducing the boost the ecu could kill the knock event quickly....
todd
todd
Originally Posted by C6C6CH3vo
Bump
3. Both (depends)?
Why and how?
Thanks
3. Both (depends)?
Why and how?
Thanks
From my experience w/ using the XEDE w/ SMART, the knock thresold is pretty high. I run a constant 2V of noise w/o the ECU pulling timing. When it pulls timing it pulls hard and its not happy giving it right back. That's what is neat about the SMART system. When you start to encounter extra noise (lap after lap on the race track, heat soak, bad gas, etc) it will pull a little bit of timing in order to keep the ECU from pulling a huge amount of timing then having to wait for it to come back. Of course, if the noise is low it will add additional timing for more power. To me, SMART was the best development for an EVO up to date.
Ralliartize It
393
Jul 29, 2016 09:29 PM
HiVoltEVO8
49
May 11, 2006 11:50 AM
