change trans oil.
Old Sep 11, 2009 | 05:00 PM
adammartini's Avatar
Unhappy change trans oil.
first off my clutch is kinda scetchy (trans might be going out of sincro) and somethimes at high rpms if your not super carefull and have it to the floor and change kinda slow it grings.
the other day when i was trying to get into third i ended up grinding the hell out of the gear. super bad its never happend to me before and lasted kinda long and was the most horible sound ive ever heard so i want to change my trans oil to make shure theres no metal shaveings in there and just to have some new oil in there.
im looking in my manuel and i can see it says "manual transaxle" api GL-4 SAE 75W-85W or 75W-90 gear oil. is this the trans? should i put that in there or is this something elce and what should go in there?
Old Sep 11, 2009 | 05:03 PM
apagan01's Avatar
GL4 100% synthetic
Old Sep 11, 2009 | 05:05 PM
Originally Posted by apagan01
GL4 100% synthetic
how manny of these do i need to fill her up
ak47po's Avatar
Bottom of page.
http://www.mitsubishiparts.net/catalog/?section=575
Old Sep 11, 2009 | 05:06 PM
vmrevo9's Avatar
Veteran: Air Force
defintely Amsoil! it will make it much better! get with apagan01, me or CGroovy2k2. 3 qts is all you need.
Old Sep 11, 2009 | 05:08 PM
Brent kuz's Avatar
I am personally a big fan of the mt90 mtl mix. My 03 tranny was a bit notchy and it took car of that. Much smoother after the change. Our synchros are weak generally speaking match that with a heavy clutch and abusive driving and well it may be time for a rebuilt to freshen it up. When you do change it no matter what you will have metal shavings! So don't freak out when your drain plug has shavings stuck on it! Watch out for a large amount of shavings and chunks of metal that would be a huge sign of damage.
Good luck!
Old Sep 11, 2009 | 05:12 PM
apagan01's Avatar
3 quarts
Old Sep 11, 2009 | 05:34 PM
Brent kuz's Avatar
I recommend to search what other people say for tranny fluid besides vendors of said product. See what shep recommends etc. I am not saying amsoil is not good but I would search and decide after reading many reviews not just a vendors etc.
Old Sep 11, 2009 | 05:37 PM
vmrevo9's Avatar
Veteran: Air Force
i had tried Mt90 first and did not like the way the tranny felt from the start. then i switched over to Amsoil and i've been sold ever since.
Old Sep 11, 2009 | 05:42 PM
thanks for the help guys ile do some more reserch on brands but probably end up trying ams. can someone tell me where i can dispose of gear oil for free, i know autozone takes engine oil but not gear
Old Sep 11, 2009 | 08:48 PM
its not a complicated prosess but for anyone that wants a step-by-step for evos heres a great link i just found.
http://www.evomoto.com/tech_info.php...aa2c5fe038de89
Old Sep 11, 2009 | 09:06 PM
yahu's Avatar
I just take it to Schucks/O'Reilly. BTW - to answer one of your original questions, yes, the manual transaxle is the tranny.
Old Sep 11, 2009 | 10:37 PM
do i NEED to change the washers on the bolts or can i just reuse them?
Old Sep 12, 2009 | 06:06 AM
apagan01's Avatar
you can re-use them, but if you have new ones change it.
Old Sep 12, 2009 | 05:29 PM
yahu's Avatar
^agreed. I re-used all except the oil drain, since I had the crush washer that came with the filter.
Sublime69
Lancer Tranny/Drivetrain Tech
Jul 22, 2016 11:31 PM
gillis13
Feb 16, 2012 07:04 PM
My03evo
Apr 20, 2011 10:26 PM
Spunkysandoval
Jul 25, 2009 06:15 AM
t3gr4
Apr 4, 2009 08:15 AM
