possibly superdumb question
Old Mar 22, 2010 | 06:46 PM
sessanator18's Avatar
i just bought an 06 evo with an ssl package from a used car dealer and its beened tuned i think since it has a tune shop sticker. My friend has a turbo diesel with a chip that changes his engine performance for towing, highway, city and smoking tires can i get something that can change a tune to different settings so i can run lower rpms on the highway for better fuel efficiency i have a 5 speed btw
Old Mar 22, 2010 | 06:52 PM
silver_evo's Avatar
Use Search and try the following things.
ECUFlash <--- ECU Reflash Software
EVOScan <--- Datalogger
Mitsulogger <--- Free and good Datalogger
Tephra 7 <--- ROM MODS!!!!
Wideband o2 <--- Must have for tuning
Timing vs. Boost <---- The Constant battle.
That should keep you busy for ever.
Old Mar 22, 2010 | 06:53 PM
silver_evo's Avatar
And no, you can not change your crusing RPM unless you change the final drive ratio by swapping the transmission diff gears.
Old Mar 23, 2010 | 10:33 AM
turbolarry's Avatar
It's only dumb if you go on thinking that you can't, or thinking that it's as easy as changing a chip.
Yes, you can change your tune, but it will require some reading and learning.
Here is the reflashing (ecu reprogramming) software;
http://www.openecu.org/index.php?title=Main_Page
Here is the logging software to see how changing the tune effects the car;
http://www.limitless.co.nz/
Cables to the laptop are available though both of the sites above.
Read here till your eyes bleed;
https://www.evolutionm.net/forums/ec.../?daysprune=-1
gkswhdl88
Oct 14, 2015 08:34 PM
fred246
Aug 19, 2015 06:31 AM
juanraulgarcia
Jun 16, 2014 10:45 AM
DFelton
21
Nov 2, 2010 10:51 PM
JohnBradley
Northwest Region
36
Jun 11, 2009 08:46 PM
