WGDC Correction Issue
Old Jun 18, 2012 | 06:19 PM
07EvoIX's Avatar
Hi All,
I am hoping someone can assist me in explaining why the WGDC is being corrected in my log by +10% even though i have my TBEC table zeroed out.
From the attached log and WG tables, is anyone able to advise what is causing the correction?
cheers
File Type: zip
Old Jun 20, 2012 | 07:40 AM
el.guerrero's Avatar
the same for me, but if i zeroed out all table like 07evoix i see on evoscan -45.
What happen?
is the same with tephra rom or stock rom zeroed out
Old Jun 21, 2012 | 12:40 PM
Boosted Tuning's Avatar
Zero out max total upward correction.
Old Jun 21, 2012 | 02:39 PM
07EvoIX's Avatar
Jay thanks for the response mate.
Are you able to advise why? i thought that table was just a limit to how much correction can be done and not an automatic correction.
cheers
Old Jun 22, 2012 | 02:21 AM
yes it is the maximun value, not a static correction.
BTW i think is not here the problem, in my evo i zeroed out all the correction in stock rom and the correction is still present like -45 or similar at idle.. i don't know why.
Any suggestion?
Old Jun 22, 2012 | 09:10 PM
07EvoIX's Avatar
are you sure you are logging the correct address? the WG and correction should be both zero at idle and even light part throttle. well it is for me.
im nto sure if maybe there is another table that determines WG activation against TPS, but mine doesnt activate till after 50% throttle. well thats what it feeld like.
the max fixed my issue and no more correction.
cheers
Old Jun 23, 2012 | 12:13 AM
i'm logging with evoscan...
i can't find the problem... i have same result with tephra mod and with stock map.
which are the correct address?
Old Jun 23, 2012 | 12:36 AM
The first picture is with stock correction table .
Correction starts at 86 of load and this is ok, but at idle i still have -64% correction.
the second picture is with ALL correction zeroed out .
there is something i can't understand .why this situation?
Old Jun 23, 2012 | 04:44 AM
07EvoIX's Avatar
i would only know the 8858 ROM address. whats your ROM ID?
cheers
Old Jun 23, 2012 | 09:27 AM
mine is 88840016.
if is not a problem can you send by email to me your rom file (hex) ?
Only to try...
il_caso1990@alice.it
Thanks a lot..
Anyone got ideas?
Old Jun 23, 2012 | 08:13 PM
07EvoIX's Avatar
im running V7 live map (88582714) so not sure if it will suit.
cheers
Old Jun 23, 2012 | 08:42 PM
Anarchy99's Avatar
Max total upward and Maf iat both are affecting correction
Old Jun 24, 2012 | 02:19 AM
in his situation yes, but in my situation i zeroed also Max total upward and wgdc vs iat..
I don't know why my car wgdc response like this
PL_MR
Aug 11, 2020 08:14 PM
mityaz
Jul 5, 2017 06:22 AM
TrendSetter
Mar 14, 2016 08:26 AM
therocket
Jun 29, 2010 02:43 PM
John F
Jul 18, 2008 01:46 AM
