OFFICIAL VIPEC THREAD - V44 PnP & V88 Thread
Old Nov 25, 2014 | 09:29 AM
  #241
jack302's Avatar
Hello everyone,
I have come here to ask the gurus of the v88 for some help.
I am currently working on a formula student car and I don't know very much about the software.
We have a sequential gearbox using a kliktronic gear switcher and what I am trying to do is to input an ignition cut whenever one of the shift button is pushed to allow for a smooth no throttle release gear shift but i can't seem to figure out how to do it. Everything else has already been programmed as we are using last year's ECU but it doesnt include the ignition cut bit.
Any help is welcome!
Thanks!
Old Dec 8, 2014 | 04:23 PM
  #242
R/TErnie's Avatar
Set your rev limiter to spark cut, and then setup a rev limiter based on a digital input... your triggered output from your shifter. Only difficult part is setting up a delay on it as well... you may get clever and design a circuit that has a adjustable delay (holds the output high to continue the spark cut during shift)
I set a safety rev limit for when fuel pressure dropped relative to boost pressure (if we ran out of fuel pump...) Base pressure + boost pressure >= Fuel pressure + 20kpa.
Old Feb 13, 2015 | 12:50 PM
  #243
bsh's Avatar
bsh
New firmware for Link and Vi-PEC ecus. Read about it here: http://www.linkecu.com/newsfromlink/...-5-3-1-release
http://www.vi-pec.com/software
Old Feb 13, 2015 | 02:55 PM
  #244
R/TErnie's Avatar
Vipec doesn't look like it's got an update? v4.10.2 is the most current???
Old Feb 13, 2015 | 10:26 PM
  #245
bsh's Avatar
bsh
This is from Vi-PEC link I linked to which states V5.3.1:
Software Version Includes Firmware Compatible Firmware Versions
Latest iVTS Version (i44, i88 ECUs)
iVTS 5.3.1.2364 V5.3.1 V5.0.1 to V5.3.1
Older iVTS Versions (i44, i88 ECUs)
iVTS 5.2.2.2245 V5.2.2 V5.0.1 to V5.2.2
iVTS 5.1.0.2009 V5.1.0 V5.0.1 to V5.1.0
iVTS V5.0.3.1785 V5.0.3 V5.0.1 to V5.0.3
iVTS V5.0.1.1731 V5.0.1 V5.0.1
Latest VTS Version (V44, V88 ECUs)
VTS V4.10.2.1784 (24-06-14) V4.10.2 V4.8.4 to V4.10.2
Older VTS Versions (V44,V88 ECUs)
VTS V4.9.9.1784 (11-11-13) V4.9.9 V4.8.4 to V4.9.9
VTS V4.9.8.1540 (18-04-13) V4.9.8 V4.8.4 to V4.9.8
VTS V4.9.3.1194 (16-04-12) V4.9.3 V4.8.4 to V4.9.3
VTS V4.9.1.1165 (28-02-12) V4.9.1 V4.8.4 to V4.9.1
VTS V4.8.82.1129 (8-12-11) V4.8.82 V4.8.4 to V4.8.8, V4.8.81, V4.8.82
Old Feb 16, 2015 | 09:24 AM
  #246
R/TErnie's Avatar
can I run the iVTS software on the v44 PnP Evo ECU? I figured the iVTS stuff was for the new generation vipec stuff???
Old Feb 17, 2015 | 03:57 AM
  #247
caged's Avatar
No more firmware will be coming out for the old v series ecus and you can't use I series firmware on them either. A bit of a pain in the *** considering they finally released dynamic traction control.
Old Feb 17, 2015 | 06:23 AM
  #248
R/TErnie's Avatar
yeah I think I got the short end of the stick on this one...
Old Feb 19, 2015 | 07:43 AM
  #249
R/TErnie's Avatar
Helpful hint for people. If you open vipec and it doesn't show any of the menu bar... CTRL-F4. Changes the view. I've forgotten and relearned this twice. Figured I would save someone else some cursing.
I'm having a problem with a Trigger Error... mivec says it is seeing a 4th cam trigger pulse??? I noticed someone else here had that problem, curious what the answer was.
Old Apr 15, 2015 | 11:52 AM
  #250
emoshel's Avatar
Originally Posted by llabmik2
Are you doing a store to the vipec. Either using the menu or by pressing Ctrl+S.
i have the same problem with my EVO9 i just purchased the car 2 weeks ago, and i am new to the entire tuned car field was wondering if any of you guys could help me with the troubleshooting as well as a remote tune, i have noticed also that due to the VVT error signal my VVT is not working
Old Sep 28, 2015 | 03:26 PM
  #251
211Ratsbud's Avatar
Hey anyone have trouble with the clutch input ? It's di8 and I'm not getting a signal for that . I switched from low to high and pull up on off with no results, it did work with the stock ecu, I'm thinking I'll have him try to ground the wire to see if it is working properly that way.
Old Sep 28, 2015 | 05:38 PM
  #252
211Ratsbud's Avatar
Which is the best clutch switch to use for both ffs and lc top or bottom ?
Also another trouble not of any significance is pin 83 is the di4 and factory it is the ac input. I set it up to run cyclic idle so after a run the car can cool down .. the input doesn't change every time the button is actuated ? Seems odd and there's no ac in the car .. any tips ?
Old Oct 3, 2015 | 07:43 AM
  #253
211Ratsbud's Avatar
How to get a baseline engine noise profile.
Is the best way to get a engine noise map laid out going to be; set knock control up to be active in all parameter except retard gain left at 0 ?
Old Oct 4, 2015 | 08:55 AM
  #254
llabmik2's Avatar
Yeah. set gain a little higher also. Around 1.5-2 that will allow you to see engine noise. Also make sure your map is setup for no knock. This will allow you to see the engine noise, so you can setup a knock map. Make sure your filter settings is also correct.
Best switch to use is the the top switch by the way if you were still working on that.
Old Oct 21, 2015 | 03:40 PM
  #255
211Ratsbud's Avatar
still having clutch switch problems
What would your settings be for oem switch ?
I I checked the switch for function with a meter but can't seem to get the ecu to see any change
