OFFICIAL VIPEC THREAD - V44 PnP & V88 Thread
Old Nov 5, 2015 | 07:59 AM
  #271
llabmik2's Avatar
Originally Posted by 211ratsbud
Llabmik, when I enable cl bc my resulted boost is 5-6 psi below my open loop baseline. Meaning my wgdc in open loop is set at 25 and when I enable closed loop I get 19-20. That's using reccomended settings and the example settings, plus I've changed them around a good bit, especially the turbo dynamics settings.
Do I need to( instead of using open loop) use advanced open loop in which I will for some reason require a net increase to wgdc for the same boost as regular open loop mode?
I have the external wastegate plumbed such that a boost ref goes to the bottom port and on that line, a tee offers a line to the ebcs which when enabled allows pressure to use top port of the ewg.
Post up some screen shots of how you have it configured or send me the map at llabmik2@gmail.com Ill take a look at it for you. PID sounds off
Old Nov 16, 2015 | 11:25 AM
  #272
211Ratsbud's Avatar
Working good llabmik thank you a ton for your help.
Old Nov 18, 2015 | 10:04 AM
  #273
llabmik2's Avatar
No problem man.
If you need any more help you have my email ratsbud!
Old Nov 20, 2015 | 05:35 PM
  #274
kayyevo's Avatar
I actually got one of these that i want to put up for sale for the EVO 9, how much do they normally go for?
Old Nov 21, 2015 | 10:28 PM
  #275
211Ratsbud's Avatar
Vented the block today..
Yep.. she vented the block..
Old Jan 19, 2016 | 03:09 PM
  #276
211Ratsbud's Avatar
delete got it
Old Jan 19, 2016 | 03:17 PM
  #277
211Ratsbud's Avatar
here it is
File Type: zip
Old Jan 20, 2016 | 11:52 AM
  #278
R/TErnie's Avatar
I'm looking for the v88 PnP if someone has one to sell.
I'd be selling my v44. lmk
Old Jan 22, 2016 | 05:09 PM
  #279
211Ratsbud's Avatar
Captain indecision sounds about correct
Just ordered a aem 12 position rotary switch for trimming boost and timing on the fly on the new race sled. 180hp stock boost and 250+ turned up. Running an I88 . Factory ball bearing ihi unit. My estimate with never looked at actually data is it's , 28-30 lb min on 1059 cc inline twin.
Old Jan 25, 2016 | 09:42 AM
  #280
R/TErnie's Avatar
^ nice!
yeah I go around and around.
Old Apr 8, 2016 | 11:28 PM
  #281
mines5's Avatar
Hi guys,
facing a little difficulty setting up 1450s in my link g4 + plug in board.
I bought FIC 1450s from a friend .
Since this car is not an evo , i have tried the suggested dead times for these injectors given by FIC
but they seem to dump more fuel in and car some times miss fires and no drivablity.
Can you suggest minimum effective pulsewidth ? what can be a good starting point ?
Any data for short pulse width adder table for these injectors ?
Thanks .
Old Jun 10, 2016 | 01:14 AM
  #282
martinPL's Avatar
The latest version of Vipec is for sale, if sb will have one please write to me:
https://www.evolutionm.net/forums/sa...er-evo-ix.html
Old Jan 26, 2017 | 03:08 AM
  #283
rip's Avatar
rip
is there an i44 or i88 PNP version for the evo ix?
if not...where to source the latest v44/v88 for same model?
Old Jan 26, 2017 | 06:27 AM
  #284
bsh's Avatar
bsh
It is called Link now: http://www.linkecu.com/products/plugin-ecus/mitsubishi/
Old Jan 26, 2017 | 09:32 AM
  #285
rip's Avatar
rip
thanks
- i followed the links to the evo9
http://dealers.linkecu.com/EVO9Plus
This item is no longer available.
if there are specs for the PNP option available - let me know pls...as well as any peripheral sensors needed (knock sensor etc) ...
cheers,
rip
