Need some Cams for 1000whp+?
GSC is now releasing 2 new grinds for the Evo 4-8 and 2 more for the Evo 9 Mivec Motor. These are not suggested for those with turbo's smaller than a 42R, these are pretty much a drag racing only set.
The S3 Cams will find there way into only a handful of cars world wide, and unless you are after 4digit numbers we offer two grinds that should work out very well for you. These will be available as a hydraulic or solid lifter lobe design.
On to the specs!
Evo 9 S3 Specs
S3 Specs gsc-6009S3S
Solid Lifter Design
Intake 290 Duration, 220@1mm Lift,11.5mm Peak lift, Veritable Centerline
Exhaust 290 Duration, 218@1mm Lift, 11.5mm Peak Lift, 116 Centerline
S3 Specs gsc-6009S3H
Hydraulic Lifter Design
Intake 280 Duration, 218@1mm Lift,11.5mm peak lift, Veritable Centerline
Exhaust 280 Duration, 215@1mm Lift, 11.25mm Peak Lift, 116 Centerline
Evo 8 S3 Specs
S3 Specs gsc-6008S3S
Solid Lifter Design
Intake 290 Duration, 218@1mm Lift,11.5mm Peak lift, 108 Centerline
S3 Specs gsc-6008S3H
Intake 280 Duration, 215@1mm Lift,11.25mm peak lift, 108 Centerline
On to the specs!
Evo 9 S3 Specs
Solid Lifter Design
Evo 8 S3 Specs
Solid Lifter Design
On to the specs!
Evo 9 S3 Specs
Solid Lifter Design
Evo 8 S3 Specs
Solid Lifter Design
On to the specs!
Evo 9 S3 Specs
Solid Lifter Design
Evo 8 S3 Specs
Solid Lifter Design
Paul is running the S2 camshaft set so neither of these... as soon as i see a good dyno graph with his new Race intake manifold on and sends me a dyno, we will see which one of these i want him to try.... i want to see that little 2.0L break 1100whp....
S2's car run on a stock engine with valve springs just fine..
Also the 1mm duration numbers posted are at the cam not at the valve. i will be updating our new website and will show all the messurments at the valve .
erioshi
Mar 29, 2010 03:39 PM
Mike.p
Mar 7, 2010 05:13 PM
Paul Nelson
65
Dec 17, 2007 05:33 AM
